Drifting setup
cosyone
Drifting setup
Post by cosyone » 17 Mar 2006 11:12 pm
Hello all,
I am picking up a 1.7 3dr 340 tomorrow which sole pupose is to drift, so welded diff, stripped interior, 13" alloys and lowered etc...
I am having lots of trouble finding suspension parts from manufactures can anyone help me please?
I have heard of 'classicwebe' from a few threads and seen the performance parts section you have.
Has anyone tips/advice for me for the parts I require to set the car up.
I do live near nev so he will be my next point of call, but last time I heard (before the ooopsy) he cut his springs and torched the leaf spring system to lower the car!!! Nuts. I want polybushes all round, bars, braces, shocks, springs..... If anyone can offer where to find this I would be grateful.
On a different note, I want the car as low as reasonably practical so the 7 x 13's don't rub.
Regards
Cosy
Don't drift faster than angels can fly
Post by SteveP » 17 Mar 2006 11:20 pm
Welcome dorifto...
Nev's had a 5 link rear set up on his 340 in the end using Avo coilovers I believe. The chopped springs and heated leafs were the beginning just to slam it :D
Classicswede does indeed have alot of tasty parts - check out the 'performance parts catalogue' thread, i think in the 'Offers' section, otherwise try a search.
7x13"s shouldnt rub... unless you get some crazy offset or you're going ridiculously low. However, practical with a welded diff - I don't even think thats possible :lol:
Post by classicswede » 18 Mar 2006 01:20 pm
Normaly the drift cars go for a 80mm drop on the front (from std factory height) these are no problem. On the back I would thing my std set of spax adjusted up would be more than stiff enough. The reason Nev made the 5 link is because he made the mistake of heating the springs - that is why they snapped. I do 50mm lowering blocks for the rear so that will get you nice and low. The secret with drifting is to have very little suspension movment.
Pm me if you want to know more.
cosyone
Post by cosyone » 18 Mar 2006 05:03 pm
Thanks Dai, spoke to nev he only lives 10 mins from me anyway. I will be seeing him later on/when I get the volvo. Looks like I will be asking for bits, especially if your the one who can supply them.
I went to pick up th volvo today but the clutch had gone so I told them to fix it, so hope to pick it up next weekend. Then drop it to nev for the work.
80mm front, 50mm rear???
Thanks for your help guys.
Post by classicswede » 19 Mar 2006 01:42 pm
That is right the rear will have sagged a little and the car will sit very well on that combo.
340cbr
Post by 340cbr » 19 Mar 2006 04:50 pm
Why do you recon to lower more the front than the back?
If I want thae back lowered 2,5cm should I lower the front more than that or 2.5cm to?
djbolf
Post by djbolf » 19 Mar 2006 06:42 pm
adding rake to the suspension (front lower than rear) , increases lift off over steer and is useful when feint drifting.
90 - volvo 340gl 1.7 , Budget drift/track toy.
Post by SteveP » 20 Mar 2006 05:06 pm
No, I think the fact that the rear of 300s sag significantly after age - so lowering the front more than the back gives an even lowering overall.
Post by classicswede » 20 Mar 2006 09:29 pm
Correct Steve. The front springs are 80mm from factory height as the lowering blocks are 50mm from todays sagged ride height. You may find the front is a little lower than the rear but that does still work well.
cosyone
Post by cosyone » 20 Mar 2006 09:36 pm
Well have spoken to Nev, just got to hope that the gentlemen can fix the car for me by the weekend, then it's off to nev for welded diff, suspension and wheels etc...
Thanks Dai for your suspension parts link, not sure if Nev uses you for that? Also any ideas for a future engine to use for drifting?
haak
Post by haak » 22 Mar 2006 07:43 pm
B230ft with a chip gives you 220 hp. Not to expensive and reliable :D
Sorry for my bad english....
cosyone
Post by cosyone » 23 Mar 2006 08:35 am
Is this a relatively cool swap?
Nev and I were discussing Renault 19's and williams engines.
Ali
Post by Ali » 23 Mar 2006 09:48 am
Not into a 340 it isn't, Haak is on about the volvo 2.3 turbo engine which is a straight(ish) swap into a 360, you've got to keep to Renault stuff
cosyone
Post by cosyone » 23 Mar 2006 09:51 am
Cheers fella will keep with the renault theme then
haak
Post by haak » 24 Mar 2006 09:19 am
Oh, sorry. Missed that it was a 340 :oops:
