Modifying A/F meter (Electronic gurus, help please)
Here is pic of meter that I do have:
http://www.janiervast.com/gallery/v/alb ... ?g2_page=4
Currently leds lit as follows:
led (lambda) A:F
1 0.98 14.4
2 0.97 14.2
3 0.96 14.1
4 0.95 14.0
5 0.93 13.7
6 0.90 13.2
7 0.87 12.8
8 0.84 12.3
9 0.81 11.9
10 0.77 11.3
I would like to change it so that leds will got lit normally, 14,7 would be led 5, but I only know that I would need to change 3 resistors, I don't know which one and I don't know what value those would need to be.
Is it possible to find out somehow?
I don't have powersource that would give proper voltage so I think I need to do just math, somehow.
Is this totally impossible to solve and it would be easier to do new one?
led (lambda) A:F
1 0.98 14.4
2 0.97 14.2
3 0.96 14.1
4 0.95 14.0
5 0.93 13.7
6 0.90 13.2
7 0.87 12.8
8 0.84 12.3
9 0.81 11.9
10 0.77 11.3
Could you post another pic or two of the back of the board Jani? I'm intrigued as to what the two small chips are, I reckon one has to be a voltage reg, but not sure. Other than that, it's not going to be easy to get a linear display, but I can at least centre it for you!
Edit: right, ones definately a voltage reg, and by modding that we can centre the display at the fifth LED.
Edit again: Ok, so definately isn't. ho hum...
Chris_C wrote:Could you post another pic or two of the back of the board Jani? I'm intrigued as to what the two small chips are, I reckon one has to be a voltage reg, but not sure. Other than that, it's not going to be easy to get a linear display, but I can at least centre it for you!
Wires as follows:
Top +12V
Center Ground
Bottom Lambda signal in
Right, you to get it centred, you need to change (in reference to picture 3784
Green next to IC - option 1 1k option 2 1K2
Green second top - option 1 120R option 2 150R
Must pick either both option 1's, or both option 2's. This will make the voltage range 0.1 to 0.9 volts, centred about the middle (lambda == 1) at 0.5V
As the narrowband is non linear, it will jump from say 4 leds to 6 quite quickly, but at least as there is a larger swing, this effect will be removed as far as possible.
Hope that helps mate, and thank Andy for working thorugh with me
EDIT: Oh, yeah, forgot to mention, as it's half 2, neither me or Andy take any responsibility for broke stuff... all maths was done in paint and my head!
And just to prove it circuit worked out, followed by some maths
Night all...
Night all...
It actually worked?!? Bonza... I'm getting better at this...
I do have only one lamda so I did connected my A/F meter to same wire that goes to Megasquirt, some A/F ratio meters need to be modified for this, there is usually 1M or 2M resistor for lambda signal and that need to be taken away so it would not cause voltage reading to get messed up, that is what I have read. But this seem to be working fine without modifying.
I think I should take bit of videos from car sometime, now there is lot of flashing lights too
