O.K. So I'm now restoring it - Now without Pics!
Re: O.K. So I'm now restoring it - Now with Pics!
will take some new pics today, wings are on, looks like I did it with a yardbrush (red oxide reacted with paint) - but it's only temporary, sand down and put on another coat eventually... anyway they wont rust!.
Most of it will be done with red oxide primer+filler, just the end of the left sill will be welded coz it's reasonably structural., rest is cosmetic, apart from that bit on left hand suspension cup, and it is only a bit - that wants drilling out and a bit of a seam weld I think.
anyhow, it's running like a dream today, been very good on fuel - deserves a days work spent prepping the rough edges etc.
I've thumped my doors from top to bottom, all over, no crumbling is going on apart from the back door, and that's been bogged up...
I have a feeling the rustproofing (replaced at big services) was done properly on this car for many years, the service history (missing) wherever it is is likely full of volvo stamps... when I had my wings over the cooker (ghetto) I noticed how much wax was melting on the inside, so the doors probably had the same treatment.
I'm getting upto 50 miles on a fivers gas (95~RON, ESSO), I have a few tweaks in place to maximise economy but it's still pretty impressive! GO VOLVO... 26 Years old, the towing eye has no wear... I think it's never broken down
---> We operate a NO-SCRAP policy, we'll never put a good car down!
Re: O.K. So I'm now restoring it - Now without Pics!
that paint... I need to figure out what to do, If the paint issues were accounted for I'd have a lot more confidence in completing her.
How can I get a good finish, the paint i got didnt match after all, I'm very wary of trying another colourmatch...
If you are painting at home you need cellulose paint, not sure what red oxide is compatible with, never used it, but a good barrier primer is etch primer, then cellulose primer, then you can get the surface nice and eventually spray with a basic compressor or can. Perfect finish can also be achieved with fine wet and dry (eg 2000) with water and then T-cut.
Getting the colour right you have 2 options;
1. Take a sample of your paint to the paint supplier, they should be able to match it fairly accuracy. I used a petrol filler cap once, you might use a wing.
2. Spray the whole car, or at least spray the panel. If its metallic you need to spray the panel anyway + then use lacquer.
Can I use Nobel gasses effectively with an arc welder, will that make clean welds, would some sort of flux help with the crappy welder? the point is the welder is free and I want to wring a good job out of it if possible...
Yeah noble gases are ideal as they don't react with much. Argon or CO2 are the most widely used.
I guess it will do the job, I can get a bit of gas from a mate - just deciding on whether to buy this arc welder.
What is the make/model? You want to look at it's lowest ampage setting. If it's 30amps or over that you'll find it very hard to weld bodywork. Needs to be about 25 for bodywork.
I found recently that Argon+CO2 seems to create more heat (or maybe the argon keeps the heat in more). Pure CO2 seems to be easier to weld bodywork with.
CO2 also seem to last longer.
Edit - MIG of course, I would not attempt bodywork with an arc welder, but some do. Frosts do a bodywork add-on for a Arc welder, I think its just a big diode to drop the voltage a bit.
it's some cheapo catlogue welder, a 30 amp, called the 130. dunno of make, not seen it yet, but it;s defo 30amp
these strut top bearings, what are they really called, what type of bearing is it, I'm lost.
