Manifolds!
Joe
Manifolds!
Post by Joe » 22 Jun 2010 11:27 am
Orytie? I have neeli finished putting my renualt 5 gt engine in my 340 and i was wondering how you flip the manifold so its away from the brake cylinder, has anyone got any pics of this or homemade manifolds? Cheers Joe
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited :)
mat_91
Re: Manifolds!
Post by mat_91 » 22 Jun 2010 06:11 pm
you cant its either make you own manifold or do this which is an very easy way of doing it
Re: Manifolds!
Post by volvodspec » 22 Jun 2010 06:19 pm
that manifold won't fit a 5gtt head. studpattern and ports are differtent
mat_91
Re: Manifolds!
Post by mat_91 » 22 Jun 2010 06:54 pm
haha didnt think of that guess you will have to make one
or bodge the r5 one some how
Joe
Re: Manifolds!
Post by Joe » 23 Jun 2010 01:19 pm
cheers will do :)
mrborrie
Re: Manifolds!
Post by mrborrie » 06 Jul 2010 08:33 am
mat_91 wrote:you cant its either make you own manifold or do this which is an very easy way of doing it
haha oh man that is awesome i should totally get that for my 66 estate when i put the 1.4 in :lol:
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
mat_91
Re: Manifolds!
Post by mat_91 » 06 Jul 2010 09:45 am
yer i had a brain wave one night thinking this up then the very next day fount pics that someone else had done it
Stefan
Re: Manifolds!
Post by Stefan » 08 Jul 2010 05:06 pm
oops :D
1978 Volvo 343 DL Black Beauty (sold)
1976 Volvo 66GL estate sold
1976 Daf 46 van (sold)
1972 Daf 55 coupe for sale
1974 Daf 33 van sold
1968 Daf Pony
1964 Daf 31
Stefan
Re: Manifolds!
Post by Stefan » 08 Jul 2010 05:08 pm
I am sure that would not clear the steering drag links on a 66
1968 Daf Pony
1964 Daf 31
mat_91
Re: Manifolds!
Post by mat_91 » 08 Jul 2010 10:21 pm
you dont have to make it exactly like that one just make it so it clears stuff
Re: Manifolds!
Post by volvodspec » 08 Jul 2010 10:48 pm
i still don't see the point of pressurecharging the original B14.4E, even with a small mitsubushi charger.
the camshaft and CR will perform "fine" untill you go over 0,2 or 0,3bar boost; setting up a carb to handle boost will require a lot of guts and knowhow; setting up a boost-capable carb to work on this engine will require a lot of guts and knowhow.. let alone the ignition wich has to be re-mapped or it will start detonating as soon as the boost kicks in.
and even then; 85/90bhp is the max you can hope for before the block gets to the point where it will blow into bits and pieces without serious AFR dyno tuning and a few internal upgrades.
so again; you're best of to start with a 5 GTT's engine in wich the cam, pistons, carb + intake manifold, cylinderhead and so on are allready matched for the 120bhp these had at the factory; the only tricky bit on those to get it in a 300 or 66 is the exhaust manifold+downpipe and clutch (stock B14 plate won't hold the torque.) clutch is allready easaly solvable with a Sachs racing paddle clutch plate
manifold will have to be a home job and whether it's a 66 or a 340, you can definatly get it to fit.
the IC system speaks for itself, and i strongly reccomend an oilcooler system with thermostate to eliminate the 5's headgasketblowing disease.
phase 2 5gtt's are the best to get your parts of, these allready have the RE209 ignition (slightly improved curve to the old RE208 unit) ; watercooled T2 turbocharger and some other small internal changes.
once you get this going and fitted properly; you are with the stock internals etc able to get it safe up to aprox 140bhp at the crank by slightly increasing the boost and get a new main jet for the carb.
after that a sharper cam, proper turbo and carb/injection upgrade will get the charged 1.4 8v above 200bhp with a hand strapped to the back, currently i'm very well underway to get my engine to that level (and slightly beyond :twisted: ). though, you might want to question yourself if that's neccasary (especially for a 66). mine allready was scary as hell to drive with aprox 150bhp (4th gear wheelspin on highway in slight rain and with reasonably good tires)
mat_91
Re: Manifolds!
Post by mat_91 » 08 Jul 2010 10:50 pm
yer thats what i thought it alot of effort for not alot of power what im hoping to do is rip the hole lot out and put something else in there with more power standard
