Oh I have buckets alright!
so it was defiantly the car that was loosing out in the cornering battle. Have you got some sporty seats now Steve?
As far as my enjoyment of the car goes, I really like the way it drives at the moment but I just want to be able to corner slightly faster, for example at Kames I was nearly coming off the track above 25 MPH going round the hair pin, which is really tight, so not surprising. I would like to think though that If I could increase the speed that I could take this corner, that would allow me to brake less, and later and allow me to progress sooner out of the corner. It would also be nice if I could improve the front to the extent where the back starts to let go a little
I think My 13s were at 27psi front and 30 rear, the front tires are knackered now anyway, the outside edges are completely worn, leading me to believe I need more negative camber.
Although maybe it is down to the fact that the cornering was trying to pull them off the rim due to the side wall flex, or perhaps 27psi wasn't enough??
These were not good tires to start with, I know that pressures and quality of rubber is a basic rule but It was all I could get at the time and I didn't have a big pump at the track with me. 3 of them are Viking and ones a Dunlop, so they're almost a match.
I cant believe you were running your fronts at 42 Chris, I had My fronts at 40 during the winter, the car drove so badly I didn't use it until I realised it was the tire pressure that was the problem.
I have some Volvo 15's but I think they're only 5.5J. The car did feel a bit better when I had them on, but they are heaver than the nice little Borbet 13s. There's always a trade off I suppose, but Im maybe getting some BBS 14s or MK1 MR2 15s that should be lighter and wider.
I had the tracking corrected to 0 degree toe after I lowered the car. Is this enough or should I be fitting adjustable top mounts and getting the car back in for a proper alignment check?
Thanks for the comments and tips your helping me work out what I need to spent my money on first!
