fornt camber?
fornt camber?
been playing about in the car, had a good look over it at the weekend (still havnt done the reverse light as yet)
just wondering if it is pos to run front camber on the 340's and whats involved in doing so
Sam
Sam
Re: fornt camber?
If you have access to a machine shop, it doesnt take too much to whip up some camber tops.
Re: fornt camber?
i used to but have finnished college now
only way to do it is custom then??
Re: fornt camber?
I haven't paid much attention to the way you would adapt a 300 fror front camber (yet) but can you not just slot the holes in the strut tops?
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Re: fornt camber?
how would you do that with out weaking the strut tops??
also is there anywhere that do strut braces for the 340 or again a custom one would have to be made?
Re: fornt camber?
custom strut tops would be the way to go but one question are you lowering it as you gain enough camber mine is currently running just over 1.3 degrees with a 75mm drop other than if your not lowering i wouldn't bother if you are lowering it id look at returning standard geometry to the suspension first
Re: fornt camber?
Have a look in my build thread mine runs camber plates on the front.
Re: fornt camber?
ye its running slight camber but didnt think it was great, i suppose with a proper set up it will feel alot harder/ feel more
