f7-r/ f7-p...
f7-r/ f7-p...
what i would like to know is how do you tell them apart??
the car i bought i got told is a 2 litre 16v which makes it the f7-p i think?
the f7-p also has bigger valves does it not?
sam
sam
Re: f7-r/ f7-p...
and would like a quick run down of what is used in the engine conversion
had the car a month and still dont really know what is used :\
obv its the clio engine
volvo gearbox - does this mean its volvo clutch,flywheel etc?
what else is swapped and changed?
Re: f7-r/ f7-p...
F7R is 2L, from Renault Megane or Clio Williams, F7P is 1.8, from Renault Clio. The f7p head has larger intake/exhaust channels from what I know.
For conversion is used, a F7 engine, F7 flywheel, v300 1.7 Bellhouse, clutch, engine mounts & Sump, and possibly alternator with bracket.
Volvo 340 L 1983
Re: f7-r/ f7-p...
is there anyway of checking if the engine is f7-r or f7-p? any tail tail signs?
Re: f7-r/ f7-p...
Longer stroke and a compression test would tell the difference. Also the engine plate number would start with F7R rather than F7P
Re: f7-r/ f7-p...
where abouts would the engine code be?
Re: f7-r/ f7-p...
To the right under the intake manifold near the dipstick. Not sure 100% because mine was taken off for painting and I never got around to re-fitting it.
Re: f7-r/ f7-p...
yes mine will probly be the same, if not a cheeky compression test will have to do
Re: f7-r/ f7-p...
Easy way to check, f7r (2.0 litre) dipstick is inthe middle of the inlet manifold and the f7p (1.8 litre) dipstick is 3/4 of the way along the manfold closer to the throttle body.
Cheers Ben
Cheers Ben
89(F) 340 DL F7P - Sold
Clio 182
Clio 182
Re: f7-r/ f7-p...
thank you for the heads up i will check this weekend
Re: f7-r/ f7-p...
They have these:
Can't remember which side of the block it's on though.
