argh! stupid 340!
scratterdan
argh! stupid 340!
Post by scratterdan » 10 Mar 2011 10:34 am
i just picked up my new 1.7 340 last night only to break down on the motorway :( :( :(
the headlights went really bright then died. and it wouldnt start.
the battery was steaming and boiling!
could this be the altenator overcharging the battery?
help. :(
jon-ovlov
Re: argh! stupid 340!
Post by jon-ovlov » 10 Mar 2011 12:12 pm
to be fair, either way youll need a new battery! once thats done, grab a voltmetre and test the connection between alternator and battery terminals, reading should be around 13.5V. if over or under by a lot, new alternator is needed. chances are battery is just nakerd.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
scratterdan
Post by scratterdan » 10 Mar 2011 12:23 pm
just fitted a new one mate and it did exactly the same thing. within 30mins the battery was overflowing. :(
jon-ovlov
Post by jon-ovlov » 10 Mar 2011 12:44 pm
itll most likley be the alternator then. fit another battery an TEST BEFORE YOU DRIVE IT. dont drive it unntil youve confirmed the voltage from the alternator. running on idle for 5 mins whil
e you test the connection shouldnt harm it. if ib doubt, turn it off.
silly question, but you sure the terminal leads are the right way round? steel braided one is negative, encased is positive, at least on a 1.4 engine. think its the same on 1.7.
other than that, somethings shorting the circuit.
Rev engine to 7K
Win at life.
scratterdan
Post by scratterdan » 10 Mar 2011 01:06 pm
yea the terminals are the correct way round :shock: :D
jus ordered an altenator so will b with me in an hour or 2.
fingers crossed this will sort it.
dan
Post by MCHUDD » 10 Mar 2011 01:12 pm
How about the voltage regulater in the alternater.
That was what solved my boiling battery problem a while back.
Cheers Mark. sm4
scratterdan
Post by scratterdan » 10 Mar 2011 01:28 pm
is that part of the alternator?
ive got a new one on order (bargain)
dan
scratterdan
Post by scratterdan » 10 Mar 2011 04:21 pm
right folks it is the voltage regulator on the back.
its charging at over 17v :shock: :shock: :shock:
where can i get one of these from.
dan
Post by MCHUDD » 10 Mar 2011 10:13 pm
Look up auto spark [car electrics in the yellow pages] for a local one.
They will be able to sort you out.
Cheers Mark. sm4
