problem after problem
RattyCoop
Post by RattyCoop » 04 Apr 2011 05:15 am
finally got the wheel bearing sorted and now the speedo has gave in. Its starting to get a little bit annoying lol. Im guessin and hoping if i change the cable it will sort it out
morgan105
Re: problem after problem
Post by morgan105 » 04 Apr 2011 09:16 am
Make sure the cable is fitted in the wheel correctly and routed properly otherwise the speedo does stop working.
RattyCoop
Post by RattyCoop » 04 Apr 2011 09:46 am
oh right so it might of just popped out when the bearing went. Makes sense now i think about it lol. I'll have a look. Thanks for that :)
Post by Ride_on » 05 Apr 2011 06:36 pm
Also make sure the circlip thats holds the end piece in the bearing cover cup is on. It will work without it but it may come out or not provide any drive for the cable, it may also wear out the square hole, again losing drive for the cable.
Post by MCHUDD » 05 Apr 2011 08:57 pm
If you are stuck for a cable, give me a shout.
Cheers Mark. sm4
