Neck size?
Neck size?
Anyone know the neck size for intake on a 360 GLS pweeeeeeeeeeeeeeze
Re: Neck size?
Air intake? I can measure a throttle body if you like, or are you wanting to put a filter on it? In which case you'll need the measurement of the airflow meter, and all mine are in the loft.
Re: Neck size?
No worries man i used the verniers at work apparently the internal diameter is 73mm. Yeah its for gettin a cone or something on. I've got carb man no throttle bodies
Chars anywho
