wireing b230ft in 360
finn
Post by finn » 13 Jun 2011 11:37 pm
god this is doing my head in can anyone help i got a b230ft in a 360 been try to get the thing to spark for 3 weeks or so now i am at my wits end has anyone done 1 that would know there way round the loom happy to pay if you can help me
wiganer31
Re: wireing b230ft in 360
Post by wiganer31 » 15 Jun 2011 12:18 am
you useing the loom out the 360 and adapting it or useing the loom that is for the lump?
finn
Post by finn » 15 Jun 2011 12:37 am
the loom from the engine
Post by volvodspec » 15 Jun 2011 03:45 pm
from what engine bay.. 2 series LH2.4 is completely different loom than from a 7 or 9 series.
you say you're trying to get it to spark. what flywheel did you use? did you use the TDC sensor located just above the bellhousing; bolted to the B230FT engine etc.
finn
Post by finn » 15 Jun 2011 07:14 pm
yes useing the right flywheel with the crank senor on the back of the block got power to the coil but still no spark
Jaspersilus
Post by Jaspersilus » 15 Jun 2011 09:28 pm
Hi Finn,
where are you from, if you put your location there maybe a member nearby who could give you a hand!
finn
Post by finn » 16 Jun 2011 07:40 pm
i am in covenrty westmidlands i have got it sparking but the injectors are not fireing so it wont start anyhelp would be great
finn
Post by finn » 17 Jun 2011 07:38 pm
its sparking and its got fuel but wen you turn it over it fire's as if the timeing is out back fireing and locking up i think the flywheel i use must be the wrong 1 can some 1 tell me if the flywheel in a b200ft 940 2.0 turbo 91 is non dulemass as there 1 at a scrap yard by me
Post by volvodspec » 17 Jun 2011 07:42 pm
leads in correct order?
have you mounted the flywheel correctly? it fits in multiple ways but the TDC marks have to be in the correct location
finn
Post by finn » 17 Jun 2011 07:59 pm
volvodspec wrote:leads in correct order?
yer the leads a right did not know it had to be fitted with the tdc marks i will take a look on the web and let you know many thanks
finn
Post by finn » 17 Jun 2011 09:40 pm
right got to the end of this problem seen wots up on turbobricks i just but the flywheel on i am such a tool lol
finn
Post by finn » 17 Jun 2011 09:44 pm
yer the leads a right did not know it had to be fitted with the tdc marks i will take a look on the web and let you know thanks for the info volvodspec top bloke
Post by foggyjames » 22 Jun 2011 01:27 pm
Did you get it right in the end? The blank in the flywheel must be in the starter motor hole when the engine is at TDC.
finn
Post by finn » 22 Jun 2011 06:53 pm
yer i did mate it running now. hopefully be on the road soon 3 or 4 weeks woz try to get it ready for retro car show mite still if i ant to busy at work
