http://www.300power.com/fakta.htm
Anyone?
I'm basically trying to work out what wheel options i have for my motor.
translation required please
90 - volvo 340gl 1.7 , Budget drift/track toy.
bit sketchy but may do for you :
Fälg
Bilmodell Bultcirkel Ø mm ET mm Navhål Ø mm
Volvo 300/400 4/100 37 52.2
Travels by car with compared bolt circle that Volvo 300/400
Fälgar from these cars changes the track width less than 15 mm.
With ET less than 37mm sits fälgen farther out and with bigger than 37mm farther in.
Bilmodell ET mm Navhål Ø mm
BMW E30, the 3 series (not 325ix) 35 57.1
Renault R5, R19, R21, Twingo, Clio, Megane, express 12, Kango 36 60.1
Skoda Felicia 38 57.1
VW Polo, Lupo, Golf -97, Jetta, Vento, fitted -96 (not 2.0i-16V, VR6), Scirroco, Corrado 38 57.1
Opel Astra A 98-, Vectra 39 56.6
Toyota Starlet, Celica 16i, Paseo 39 54.1
Nissan Almera 40 59.1
Renault Espace -91 42 60.1
Seat Arosa 43 57.1
Seat Ibiza, Cordoba, Toledo -98, Inca 38 57.1
Fälgar from these car models must be provided with spcer-plattor since the changes the track width more than 15 mm. The exists also risk that fälgarna takes in since ET-måttet is bigger (sitter longer in) than originals fälgarna.
Daihatsu Charade, Applause, Sirion, bits Move 45 56.1
Honda Civic, Accord -90, Prelude, Concerto, Quinett 45 56.1
Kia Sephia, Shuma 45 56.1
Nissan Micra, Sunny, 100 NX 45 59.1
Rover 200/the 400 series 45 56.1
Suzuki Baleno, Wagon R 45 54.1
Toyota Corolla, Carina -97, Tercel, Yaris 45 54.1
Hyundai emphasis -99 46 54.1
Mitsubishi Carisma 1.6 96-, Colt 92-, Lancer 93- 46 56.1
Daewoo Nexia, Lanos, Espero, Nubira 49 56.6
Opel Ascona, Corsa, Kadett, Astra -97, Vectra A -95, Calibra A -97, Tigra 49 56.6
Renault Laguna -95, Safrane -96 50 60.1
Mazda 121 -95, 323 90-, Demio, MX3, MX5 45 54.1
Decks:
Decks with same rolling circumference as 175/70 R13
SBP approves maximum difference in rolling circumference on+/- 5%.
What as is max breadth on decks that SBP approves knows I not, but I have not taken with broader decks than 205 and not bigger fälgar than 17 " (which should last bigly…)
Breadth Profile Fälg Circumference Difference%
175 70 13 180.7 0.0
185 65 13 179.2 -0.8
185 60 14 181.7 0.3
195 55 14 179.1 -0.8
205 55 14 182.5 0.9
185 50 15 177.8 -1.5
195 50 15 180.9 0.1
205 45 15 177.6 -1.6
195 45 16 182.8 1.1
205 40 16 179.1 -0.8
205 35 17 180.7 0
Fälg
Seat Arosa 43 57.1
Decks:
175 70 13 180.7 0.0
185 60 14 181.7 0.3
205 55 14 182.5 0.9
195 50 15 180.9 0.1
195 45 16 182.8 1.1
205 35 17 180.7 0
the 180 and 170 numbers will [maybe] be the circumference of the tyre !?
i use a similar measurement to work out how fast my car goes as its no speedo . the only difference is that i use 1 revolution of enginge[tdc to tdc] and measure to distance the car moves and from that you can calculate how fast you are going in any gear at any rpm[bit complicated but it works].
from last tests our car moved;
1850mm on our 14's
1870mm on our 13's
but i wont bore you with that :]
1850mm on our 14's
1870mm on our 13's
