What spark plugs should i buy?
Posted: 30 Apr 2006 11:01 pm
by NasoNex
I have to buy a new set of spark plugs to my car.
Volvo 360 GL 87 mod. B200K.
What plugs should i buy?
NGK xxxx
Champion xxxx
And are there any major differencies between the plugs i can use on my car?
Thanks.
Posted: 30 Apr 2006 11:07 pm
by girlracer
Either go for NGK or Bosch. what i've heard Champion plugs are rubbish!
Posted: 30 Apr 2006 11:14 pm
by NasoNex
Yes. but what is the name of the spark plug.. NGK BR9ES f.ex .. ?
Do you know?
sparks
Posted: 01 May 2006 07:36 am
by mgarageu
NGK BPR6E(S) or Champion RN9YCC...i had AC Delco C43CXLS on my 360 with B19A...were good ones...
Posted: 01 May 2006 07:50 am
by Raod
In my 360 '87 B200E I have Bosch WR6DC. It also admit Champion RN7YCC or NGK BP6ES.
Hope that helps you.
Posted: 01 May 2006 11:21 am
by NasoNex
Hmm, okay. Thanks.
What a awesome weather. *Time to wash the car*
Have a nice day guys.
Posted: 01 May 2006 02:42 pm
by NasoNex
The only one they had at the gas station was NGK BPR6E .. and they was designed for Volvo. The Haynes manual says that i should use NGK BP6ES.
I guess theyll work? Anyone who knows the difference between BPR and BP?
Posted: 01 May 2006 02:58 pm
by antiekeradio
R is for Resistor.
a resistor type is made to eliminate static/interference signal with Radio/TV/com signals.
doesn't make a big difference when you have a proper set of leads and a electronic ignition setup (old timers are more sensitive)
Posted: 01 May 2006 03:00 pm
by Raod
The "R" on the reference number means "resistor". There's no problem, buy and install it, the car will runs fine.
