Dexter
Post
by Dexter » 07 Jun 2006 01:51 pm
I want to change fuel system on my Volvo. I want to change the carburettor on injector.
I have already bought injector and all it's parts...
I had question... Can you give me the scheme of connection injector with other parts?
And also the scheme of connection of electric wiring.
Help me please.
Dexter
Post
by jtbo » 07 Jun 2006 02:58 pm
Citroen ZX Dturbo -97 -daily-
Dexter
Post
by Dexter » 07 Jun 2006 03:13 pm
thanks , but this is not appropriate
mac
Post
by mac » 08 Jun 2006 02:22 pm
Hi Dexter, To ask the obvious questions first.
What engine does your 300 have in it ? and what engine does the injection system you have come from ? Is it a Volvo injection system ?
You say you have the injector and its' parts - did you get the whole system including manifold, ECU, fuel pump, air mass meter etc. etc.
If all you need is a Volvo wiring diagram for say a Bosch LE system on a 360 I can easily e-mail you a copy but I really need to know more about exactly what you are trying to do. (for example you say injector - meaning one - all injection 360s' would have a rail on the inlet manifol with 4 separate injectors. Or are you trying to fit a 440 B18U single point unit to a 300 with a B172K engine ??).
If your car is a 360 B19/B200 (carb) and you have the system from a 360GLT (and you have ALL the parts). it is a relatively easy task but even so it won't be an afternoons job.
All the best Mac.
d3k4y0
Post
by d3k4y0 » 08 Jun 2006 06:21 pm
mac wrote:Or are you trying to fit a 440 B18U single point unit to a 300 with a B172K engine ??
How big a job's that? sounds like fun!
Dexter
Post
by Dexter » 08 Jun 2006 07:32 pm
mac wrote:Hi Dexter, To ask the obvious questions first.
All the best Mac.
Hi mac!
Yes , i have engine B200.
Injector from engine B200 , but i don't know how all parts connection.
my e-mail :
dexter_88@mail.ru pleeeasee
mac
Post
by mac » 08 Jun 2006 08:43 pm
Hi Dexter,
Дайте мне день или 2 и я попытаемся найти изображение системы установленной на автомобиль поэтому вы можете увидеть куда все идет. Я также сделаю перечень компоненты, котор вы и находите вверх по правильной монтажной схеме.
(Give me a day or two and I will try to find a picture of the system installed on a car so you can see where everything goes. I will also make a list of the components you need and find up a proper wiring diagram.)
Regards Mac.
ps Excuse my Russian.
Dexter
Post
by Dexter » 08 Jun 2006 09:09 pm
Regards Mac.
ooooo!!! thanks !
I was very surprised when i see Russian language!
You Russian are very good!!
Post
by jtbo » 09 Jun 2006 07:59 am
Here is loads of information, check L-jetronic parts as that is what your injection system is. There is few variants of L-Jetronic, but basics are same with all of those.
http://www.vectorbd.com/bosch.html
Here is workshop manual of Volkswagen L-jet, again basics are same, some minor differencies possible.
http://www.conservatory.com/vw/manuals_ ... ronic.html
Maybe some help?
mac
Post
by mac » 09 Jun 2006 02:07 pm
Dexter,
I have sent you 2 e-mails to your address, one with a basic description of the LE system, a photo of the engine bay of a 360 with the system installed, and line drawing of all the components and hopefully how they connect up.
The second mail has copies of the factory wiring diagrams and system specifications.
I have also made a short list of things you will need but may not have got with the parts you bought. (mechanical fuel pump blanking plate ??, coolant temperature sensor for the ECU, fuel pump mounting plate and heat shield to protect pump from exhaust. etc.)
Do post and let us know hoe you get on.
REgards Mac.
Dexter
Post
by Dexter » 10 Jun 2006 03:25 pm
mac wrote:Dexter,
REgards Mac.
Здравствуйте Mac!
Большое Спасибо Вам за информацию! Это хорошая информация..!
Можете ли Вы , пожалуйста , отправить фотографии шлангов(трубок) которые идут от инжектора к датчикам двигателя , от инжектора к катушке зажигания (Renix) и остальные...
Hi Mac!
thanks for info! It's a realy good information!
Could you send photos hose( connective tube) from injection system to engine sensors, from injection system to Renix and other to my e-mail... please
Cheers Dexter
mac
Post
by mac » 10 Jun 2006 04:00 pm
Dexter, not totally sure what hoses you mean.
The only sensors with any hoses are the fuel pressure regulator (has a simple rubber vacuum pipe to the inlet manifold, as does the vacuum advance of the Renix) and the air mass meter which is connected to the throttle body by air trunking. All other sensors are connected by the injection wiring loom.
Can you be more specific what info you need.
Best regards Mac.
Dexter
Post
by Dexter » 10 Jun 2006 04:16 pm
mac wrote:Dexter, not totally sure what hoses you mean.
Best regards Mac.
oohhh... it is difficult to speak on different language...
Send me please photos your engine and injection... May be I saw and understand this system
Cheers Dexter
mac
Post
by mac » 10 Jun 2006 04:31 pm
Hi again Dexter - slight problem - I do not have a 360 with injection !!
Any member able to help with a few digital pics of an LE system ????, I am sure Dexter would be very gratefull.
Mac.
Dexter
Post
by Dexter » 10 Jun 2006 04:43 pm
mac wrote:Hi again Dexter - slight problem - I do not have a 360 with injection !!.
mac wrote:Any member able to help with a few digital pics of an LE system ????, I am sure Dexter would be very gratefull.
Mac.
Yes . Can everybody help me?
