AFM
blackbox
AFM
Post by blackbox » 15 Nov 2007 11:24 pm
hi guys its been bit since ive been here but does anyone know if a different air flow meter will fit on a 360 b19e efi or do i need to change the cpu in the car
1984 360glt B19 black
Post by trabitom99 » 16 Nov 2007 09:39 am
Hi blackbox!
I was once told that if the part no. of the new air mass meter is not the same as the one which was originally fitted, you also need a different ECU. If you change both parts then that's OK.
But I haven't tried it myself ...
Post by Chris_C » 16 Nov 2007 12:25 pm
Afaik... 360's only had one version of LE jet, not multiple mapped versions, so any ECU change would be a major undertaking, especially considering it's one of very very few open loop electronic injection systems.
Isn't the flappy paddle on the 360 just a variable resistance, and the wiper gets knackered? I'd either replace the pot, or just abuse it with a good contact cleaner if you think yours is playing up
blackbox
Post by blackbox » 16 Nov 2007 11:12 pm
ok that sounds good i will try that
thanks for the reply
