blackbox
Post
by blackbox » 02 Dec 2007 09:52 pm
As topic my 360 B19E fuel injected run ok but it idles with a strange miss its not like its just one cylinder tho it runs the dies for a second the keeps running so it idles at 900 rpm then goes down to 300 rpm what could it be any ideas
thanks guys
blackbox on 07 Dec 2007 06:22 am, edited 1 time in total.
1984 360glt B19 black
jarlidge
Post
by jarlidge » 02 Dec 2007 10:01 pm
hi
i had that on my 360 gle and that turned out to be a air leak in o the fuel line, i don't know if that could be the same on your glt.
blackbox
Post
by blackbox » 02 Dec 2007 10:40 pm
how did you find where it was
jarlidge
Post
by jarlidge » 02 Dec 2007 11:23 pm
i had to check all my fuel lines and found that 1 was leaking. once i repaired it i never had any trouble.
blackbox
Post
by blackbox » 02 Dec 2007 11:37 pm
ok so i will look all the way down then thanks
jarlidge
Post
by jarlidge » 02 Dec 2007 11:38 pm
its a chance it might be that, its worth a try.
blackbox
Post
by blackbox » 07 Dec 2007 06:27 am
thanks i took vacuum hose off fuel pressure regulator and fuel came out so put new reg on and fixed
so Thanks again
jarlidge
Post
by jarlidge » 07 Dec 2007 06:59 am
hi
glad i could help!
jeff
