Breather for 16v block
xtrmjks
Post by xtrmjks » 04 Apr 2008 05:56 pm
Has anyone had any experiences?? I;m looking to run breather from std out let (removing plastic "box") and anywhere to went the head??
Post by classicswede » 04 Apr 2008 08:02 pm
And the question is exacly?
xtrmjks
Post by xtrmjks » 11 May 2008 10:33 am
I'm making a breather (catch tank) system for My turbo, breather on crank case to catch tank with filter and wondering has anyone done breathers from valve covers??
Post by 340GLT » 11 May 2008 03:00 pm
Not on a redblock but have on mine.
Post by SteveP » 11 May 2008 04:21 pm
Try turbobricks, there's a fair few more people with 16v redblock experience on there!
volvorsport
Post by volvorsport » 12 May 2008 01:04 am
keep the std breather , its an oil seperator , pipe from that into a catchcan 4 inch round 6 inch long , that should have a hose venting to atmosphere from the top of teh cylinder to underneath the car or a chassis member . you can vent the oil filler cap using an early steel one , its advisable to have a return to the sump , since youll be blowing a fair amount of oil out at high boost , but then youll also be breaking the gearbox at that high boost . :D
Post by foggyjames » 18 May 2008 12:39 am
You can vent the head by using the filler cap from an OHV redblock (from a 140, Amazon, P1800, etc) which has a fitting and hose attached to the cap. They do tend to blow oil past a couple of seals (mainly the filler cap!)once you wind the boost up. The standard breather is fine for a stock engine, but can't really cope with 20+psi of boost.
