360 Exhausts
360 Exhausts
Post by SteveP » 12 Apr 2008 02:02 pm
Just a quick note.....
Earlier style backboxes don't fit to later middle boxes much to my annoyance! :roll: The earlier bore is smaller so the backbox join wont go over the middlebox (it's identical diameter)
kaos
Post by kaos » 12 Apr 2008 04:58 pm
so get a slightly larger bit of pipe than both of them and slide that other both parts and clamp.. and Voila.
germ
Post by germ » 12 Apr 2008 06:55 pm
aha, this explains clouds problem!
Volvo 340 Image 1988
Post by filthyjohn » 13 Apr 2008 04:26 pm
My 60 had loads of bother getting the late backbox to seal around the middle pipe, then when checking the pictures in the motor discount book, I noticed the different diameters. Turns out mine has an early style middle pipe, which the factors say is NLA.
Post by SteveP » 14 Apr 2008 09:24 am
Hmmm does the early style middle pipe fit on a late downpipe then, John?
Post by Chris_C » 14 Apr 2008 09:41 am
Steve, I agree with Kaos, a 6" sleeve would do it perfect. As to where you'd get one from... no idea ;) Got to be an exhaust shop round you who'd do it though.
Post by SteveP » 14 Apr 2008 10:35 am
Yeah, a sleeve will most likely be the plan, but I'll have to cut down the backbox to compensate for it not slipping over the middlebox
Post by classicswede » 14 Apr 2008 01:17 pm
Or just get the pipe flared?
Post by filthyjohn » 14 Apr 2008 02:07 pm
SteveP wrote:Hmmm does the early style middle pipe fit on a late downpipe then, John?
Pretty sure, as I fitted a new late-model DP to mine. Just a pattern part but it was a good close fit, needed some swearword-lube to force it on.
Cloud
Post by Cloud » 15 Apr 2008 11:14 pm
Well thats got me thinking...so the back box i have will go on...it just wont connect to the middle section. Sleeving the pipe is worth a try i suppose....hmmm still unsure though as the connection is pretty close to a flare in the pipe...I'll get some pics of the zorst 2moz and someone who knows about this can confirm lol.
B Volvo 360 GLT - 2.0i 52k
N Volvo 480 Celebration - 2.0 140k!
P Hyundai Coupé SE - 2.0i 16v 99k
