Rev counter problems
cheshire190e
Post by cheshire190e » 13 Jul 2008 04:04 pm
Hi everyone, just a small problem.
Its not really that major but just annoying, my rev reads far too low. When my car is idling the needle is just below 0. when i press the throttle the needle moves steadily but still seems too low. its as though its only reading 70%
does anyone know what may cause this?
Matt
1987 Volvo 340 1.7
Bazboy
Post by Bazboy » 13 Jul 2008 04:10 pm
well i dont have a speedo so rev counter so wont be able to give much advice but just a thought, could it be that the needle has been twisted somehow so when the cars revving at say 3000 rpm the needle only reads 2000 if you get what i mean.
This could be sorted by just opening the dash and twisting the needle back to its original position but like i said i dont have a rev counter so probably best to wait for someone else who does lol but just a thought.
Dan.
cheshire190e
Post by cheshire190e » 13 Jul 2008 05:28 pm
sorted it, im such an idiot. You were right the needle had just rotated on the pin. must have happened in the post when i recieved it.
1987 Volvo 340 1.7
kaos
Post by kaos » 13 Jul 2008 05:59 pm
ah but now you wotn know if its reading right or not!
as you'll have just moved the pin so it'll be over or under reading now.
best thing would be to get an after market tacho that reads right wire it in and then if yours reads 200 rom at 60 and the after market one reads 3k. you know you need to blue tack yours in place at 2k then wind it forward to 3k so it reads right.
best way to do it.
Bazboy
Post by Bazboy » 13 Jul 2008 06:40 pm
That makes senses lol, i wasnt meaning just randomly select a rpm you like and set it at that lol
I think there is a tool you can use to find out a cars rpm look in the haynes manual it talks about it in there somewhere.
Dan
cheshire190e
Post by cheshire190e » 15 Jul 2008 02:30 pm
I'm not 100% on this but I have it now so when the ignition is off the needle is at 0, where as before it was about a cm below, it seems right
now.
1987 Volvo 340 1.7
Post by 340GLT » 16 Jul 2008 12:49 am
The needle should sit at 0 with ignition off.
cheshire190e
Post by cheshire190e » 16 Jul 2008 08:05 am
yeah cheers adam, i thought that could be the case. seems accurate now.
1987 Volvo 340 1.7
