Rattling sound on tick over
cheshire190e
Post by cheshire190e » 05 Sep 2008 12:11 pm
Hi everyone,
my car makes a rattling/clanking sound when my car is ticking over in neutral but then stops when i put my foot on the clutch.
is this the clutch release bearing gone or something else?
Matt
1987 Volvo 340 1.7
sven360
Post by sven360 » 05 Sep 2008 01:12 pm
Idler gears-they all do it.
Relax turn up the dukebox and carry on as normal.
Write it in your heart.
The code of the West.
WooDooUK
Post by WooDooUK » 05 Sep 2008 02:04 pm
Doesn't realy help but mine dones exactly the same, and thats with a brand new Release Bearing. but that not to say it was a quality one :)
never used to when it was 1.4 tho.
antiekeradio
Post by antiekeradio » 05 Sep 2008 02:39 pm
check for play/movement in the clamps that connect the rubber part of the driveshaft to the teethed bits of the clutch shaft/gearbox shaft.
sometimes the hex bolts come loose...
also, you might want to check for play between the clutch plate and the clutch shaft.
Another source of sound (usually not rattling/clunking) can be the clutch shaft bearing 'staartstuklager'
these usually become noisy very quick after installation, but last quite long when you just let them be noisy.
stuartB
Post by stuartB » 05 Sep 2008 02:56 pm
I realise this is probably teaching you to suck eggs but...
in neutral, the propshaft is constantly spinning. when you pop the clucth, this is no longer the case.
perhaps you are hearing the noise of your 'shaft spinning (oo err). Mine does this too.
whats it like under load? i.e in gear, driving along?
Volvo 360 GLS, 1984, 2ltr 8v SOHC, K+N filter, 2" straight thru pipe, no middle box, lowered 2", Landrover 90 shocks, BBS rims
cheshire190e
Post by cheshire190e » 07 Sep 2008 12:32 pm
its fine when its driving, its just when its in neutral and idling. ill just ignore it and check those hex bolts.
1987 Volvo 340 1.7
Bazboy
Post by Bazboy » 07 Sep 2008 01:25 pm
If you start to hear a chunking when changing gear then your props about to go, mine chunked when changing gear then suddenly went, so now as soon as i hear chunking a get under and give her a tighten, at least until i get the new bits for her.
germ
Post by germ » 07 Sep 2008 02:58 pm
do you mean your prop fell off? like at one end(normally the rear end)
if thats the case you havent got it on right it needs to be tapped down further, an tightened well.
i also have that clunking sound at idle that goes with the clutch being depressed. i know my engine moves quite alot a idle/its rough, so that could be a part of it, the engine might not be alighed right, but i think its most likly the bearing where the prop spline is (engine end)/ if that spline is slightly bent.
Bazboy
Post by Bazboy » 07 Sep 2008 05:48 pm
No the splines rounded of and i was left stuck in the road with a car which screamed when i tried to move away, the clunk wasn't very loud it was the prop moving ever so slightly against the clutch shaft splines. that was my first prop im on number 2 which will be replaced soon as it too has started to go a little.
