sliding
sliding
Evening
i have asked about what engine to go into my 340 later on this/next year, but i want to make her a bit tail happy, seen the mods for the rear shocks deffinately going to do that, lowering blocks/springs,
heard about welding the diff? whats peoples opinions on this, also has any done it? is there a guide to doing it?
lads
lads
If you want to do it on the cheap, just put the worst tyres you can on the back, pump them up to 45psi and wait for rain. Lowering mine helped a lot, but a bucket seat is possibly the best single upgrade for doing skids, as you won't be falling about the cabin.
I only kick it out in the wet really, partly mechanical sympathy and partly because you need SERIOUS commitment in the dry with a 1.4
Welding the diff will make things a lot easier.
Define drifting, making it lose the back end is not the same as holding it there. So unless its either wet, on 155 tyres or over inflation or a combination of them all then 1.4s dont dry drift with an open diff on tarmac......kaos wrote:
dry drifiting 1.4's is easy
Or if you are going slow enough just spinning the inside wheel
Big commitment needed.
Should be some diff welding guides around the intertrons I'd imagine, or a search on here, people have certainly posted pics of it
Jason B
If you really want to weld your diff then you need to weld the spider gears in the middle together, NOT the ring and pinion!. However, you'll need a really high powered welder if you want it to hold for any decent length of time. Also, the gears retain a fair bit of oil which is bad news if you want to get a decent weld without it bubbling up everywhere and putting lots of impurities in. In short, unless you have a decent 180A+ mig and are fairly competant, then I would get someone who knows what they're doing as its pointless making a mess of a perfectly good diff only to learn you aren't able to do it.pills wrote:okies, well at the scrap yard near me, has a spare 2dr 340, goona pikey a few parts so gonna nick the rear diff/gear box?
what do i need to weld and weld what to what?? any faqs?
liam
sure there is a guide how to weld diffs on www.trampdrift.co.uk
had mine welded on my 360 and my 340, makes getting the back end out much more predictable . . .
probably wont be able to drift a 1.4 340 that well in the dry, unless its on nice loose ground, but in the wet you should be able to get some sideways action no probs !
go for it matey
go for it matey
