funny noises help please
kds19
Post by kds19 » 04 Oct 2008 12:49 pm
right its started of as just a quiet ticking noise every now and again under acceleration, then when i had a full car it progressed to a whurring noise under acceleration from underneath the back of the car somewhere now it makes a kind of grinding noise under acceleration, my dad seems to think that its the prop shaft, and i think it could be the half shafts as if i get underneath and shake them they rattle and are quite slack, i dont think its my diff as it makes no noises going round corners. could someone please shed some light on this as i dont have a clue what it is and it gets worse every time i drive it and i need it for work. its a 1.4 340 if that helps any.
kev
MJ
Post by MJ » 04 Oct 2008 03:49 pm
Just a completely random idea - have you checked the oil level of the differential, as they have a tendency to leak. I don't know if it would make noises like that though...
Bazboy
Post by Bazboy » 04 Oct 2008 08:39 pm
Get under the car if you can and check if the prop is loose or if it rotates slightly around the clutch and gearbox shafts, cause when mine gets loose its makes a whirring noise. If all seems good with the prop then look towards the gearbox and diff side of things.
Dan
kds19
Post by kds19 » 05 Oct 2008 12:15 am
so you think it could just be loose? do i put the car in gear or anything to check properly?
kev
Bazboy
Post by Bazboy » 05 Oct 2008 01:03 am
Yea could of just come loose, mines done it a few times but mine is pretty mucked up lol, Just get some one to operate the clutch for u so u can rotate it and check that it doesn't move on the clutch to gear box shafts.
Good luck dan
kds19
Post by kds19 » 05 Oct 2008 10:26 pm
right checked that and its not loose and the half shafts are fine so im buggered if i know, ill top up the diff oil soon and if that doesnt work the im screwed lol
