i tried to adjust my rear koni adj dampers but i cant get the bump stop out its in there soild
anyone got any tips on how to remove them?
and anyone know how stiff they go??
kev
koni adjustables help?!?!
85 360 GLT drift beast
clutch kicks ahoy!!!!
Re: koni adjustables help?!?!
There's a Koni leaflet in that big wad of paperwork I gave you - i think I had them set to 3 half turns out of a possible 5 - can't remember how many clicks there are but they're set at a little over half maximum stiffness. So will go quite a bit stiffer! There are holes in the casing to stick a wee phillips screwdriver through and lever out the bump stops if I remember correctly.
http://www.amdtechnik.com/technical.koniadjustment.cfm
http://www.toperformance.com.au/tech_fs.html
cheers ronnie found the leaflet
will give it a shot after the drift day
