My rear washer doesnt spray water
valman
Post by valman » 23 Mar 2010 05:53 pm
help is needed fellows
, my rear squirter does feck all. i can hear the pump going when i press the button and if im lucky i get a tiny tine dribble from it, but only after a while, what could this be? i dont think its leaking as there are no puddles inside the car and its not pinched anywhere, blockage? but where :?
thanks all 340pw
CBA
Re: My rear washer doesnt spray water
Post by CBA » 25 Mar 2010 05:19 am
Pull the pipe off near the squirty - get a pint of water and blow it down the pipe the wrong way - empty the reservoir (the crud will be in there now). also check the squirty itself is not blocked. that can be "manually reverse flushed" too, or a piece of steel wire poked in the hole and wiggled around can do the trick.
valman
Post by valman » 26 Mar 2010 12:41 am
thanks dude, will give it a go tomorrow :) :)
valman
Post by valman » 27 Mar 2010 05:53 pm
sorted, was the actual nozzle that was stuffed - found out by putting a hose into the system from the front and it blew the hoses off the nozzle. so ran some water through that and sorted :D
CBA
Post by CBA » 26 Apr 2010 08:24 am
forcefully forward flushing... ok :D
