Duchess The Volvo 340 CVT
JFB
Re: Duchess The Volvo 340 CVT
Post by JFB »
Yes
benji1985
Post by benji1985 »
JFB wrote:Yes
i have kick down and rear wiper near the gear selector, so had to use the green switches for things
benji1985
Post by benji1985 »
Hello all.
So as you all know she passed the MOT, however upon driving her i was not getting much "gearing up", so some investigation was needed.
It turns out that the outer seals were not sealing and letting air in, new seal were obtained and and lot of reading later and thanks to Mac for all his help in making me understand.
Image20171005_211353 by Benjamin Charlton, on Flickr
As you can see the seal feel apart
Image20171005_211359 by Benjamin Charlton, on Flickr
Image20171005_211633 by Benjamin Charlton, on Flickr
Image20171005_212212 by Benjamin Charlton, on Flickr
Image20171005_212218 by Benjamin Charlton, on Flickr
Then proceed with the other side
Image20171006_205649 by Benjamin Charlton, on Flickr
Now just got to wait till i cna put them back on to the car and test her.... fingers cross
Now for some R+D, I am replicating the De-clutching servo, it is coming on quite nice
Image20171007_131846 by Benjamin Charlton, on Flickr
Image20171007_131903 by Benjamin Charlton, on Flickr
I will post when i have managed to test drive her
Ben
Post by bogbasic »
Awesome work.
benji1985
Post by benji1985 »
Good day all, Well today is a good day, managed to get the repaired parts back on the car.
17/10/2017
With the repaired parts fitted back to the car and tested the vacuum on both sides at the drum and the 4 way vac valve, she is now holding vacuum.
So time for her first proper outing, just a short trip across the moors as it was raining.
Image20171017_174523 by Benjamin Charlton, on Flickr
Image20171017_174529 by Benjamin Charlton, on Flickr
Image20171017_174535 by Benjamin Charlton, on Flickr
Image20171017_174549 by Benjamin Charlton, on Flickr
Image20171017_174559 by Benjamin Charlton, on Flickr
I can confirm that the new seals have helped a lot, however there is still an upgearing issue, so going to test the electronic side of things.
Will keep you posted.
Ben
Looks awesome Ben! Must have been a great drive.
360beast
Post by 360beast »
Good to see it out on the road :)
The passenger headlight wiper is messing with my brain haha.
Post by bogbasic »
Awesome work, epic and evil. Are you sure its got enough of that 'new car' feel ;-?
benji1985
Post by benji1985 »
360beast wrote:Good to see it out on the road :)
Yep i'll fix that, i'll be honest i didnt really notice that, there are still a few little bits that need to be sorted.
benji1985
Post by benji1985 »
bogbasic wrote:Awesome work, epic and evil. Are you sure its got enough of that 'new car' feel ;-?
I wouldnt say "new car" but does feel good, she a little "go-kart"
Ben
Who needs new cars when you can make them yourself :)
Post by MCHUDD »
Hi Ben.
That is just brilliant work. I remember last year going to a show and
seeing Ride-ons rebuilt 360 and going Fxxk me, that is class. You must be
a proud man to have built that . Well done.
sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69
benji1985
Post by benji1985 »
MCHUDD wrote:Hi Ben.
Thank you
I am quite proud of myself, still have a few little things to do but they have to wait, need to sort out why she is not upgearing quite right, working through the fault guide from mac atm.
Can't wait to have her at a show, soon I hope. :D
Ben
Post by bogbasic »
I can only second Mark's comments, but I wonder what else he thought at the meeting.
benji1985
Post by benji1985 »
Hello all
02/11/2017
I am please to say that i finally found the problem with my up gearing with thanks to Mac, and James. the transistor in the black box was replaced which saw the solenoid click at 1800rpm or greater, so she went on a quick drive.
this is a video!!
Image20171102_124913 by Benjamin Charlton, on Flickr
Image20171102_124954 by Benjamin Charlton, on Flickr
Image20171102_125024 by Benjamin Charlton, on Flickr
Image20171102_125047 by Benjamin Charlton, on Flickr
Image20171102_125055 by Benjamin Charlton, on Flickr
However she was not up gearing still, so headed back and tested the vacuum, there was a small vacuum so decided to try the other 4 way valve I had, this yielded a much greater vacuum, and now while driving along if i hit the low hold switch the revs ramp up and then down after the switch is turned off. So it would seem that all aspects of the CVT were at fault, the seals in the drums, the 4 way valve and the black box. However i am glad to say that she is now driving at last, the belts still need tensioned correctly and the de-clutching servo needs adjustment along with maybe the clutch shims.
this is a video!!
Image20171102_132358 by Benjamin Charlton, on Flickr
Image20171102_132551 by Benjamin Charlton, on Flickr
Image20171102_132614 by Benjamin Charlton, on Flickr
Image20171102_132618 by Benjamin Charlton, on Flickr
Image20171102_132625 by Benjamin Charlton, on Flickr
Image20171102_132639 by Benjamin Charlton, on Flickr
Image20171102_132654 by Benjamin Charlton, on Flickr
Image20171102_132704 by Benjamin Charlton, on Flickr
