Re: MY78 343DL Black Beauty - Exhausted
Posted: 26 Dec 2011 05:11 pm
Well I thought I'd best start a thread for this car.
I recently got round to drilling some holes in some number plates. This has taken me some time, as I first had to register the car and hand over money (€200
). Then I had to wait a while for the plates to be made up and go and fetch them. Couldn't fit them when I got them, as I was waiting for some wheels along with the number plate brackets to come back from the powder coaters...Then I needed to find some less grotty screws for said brackets. Now it's just bloody cold outside! Excuses, excuses.
The front number plate is held on by two regular plastic number plate screws. These screws are secured in 20mm long slots to allow horizontal variation of number plate holes depending on how you drill your plate. The 2 brackets are pressed steel and have two rubber strips per side between the bracket and front valance. They are secured to the valance by two screws (4.2mm x 16mm pan-head Pozidrive self-tapping) into plastic inserts in the valance.
The rear number plate is held on in a similar fashion, however the plastic number plate screws this time screw into captive plastic nuts which are held in place by a slider bar which is in turn screwed into plastic inserts on the rear panel.
The front ones were quite rusty and bent where the plate must have taken a knock at the bottom edge, but I straightened them out as best I could. The rear bar was also surface rusty, so I just chucked them all in to get blasted and powder coated. Front ones although crappy, at least look like this now:
and the rear:
Goodbye old plates, hello new:
Now there was the lengthy period of careful consideration and many, many measurements. Being old-school plates with riveted-on digits, I had a take care not to plonk the holes in the wrong place and in the gaps between the digits.
The rear one was quite easy as there is a lot more horizontal movement available.
The front one was a bit more difficult with less horizontal movement and the spacing of the mounting brackets, so I had to move the plate down a bit.
With plastic screws, you can readily obtain them in white, yellow, black and blue - but not red. So had to get some red paint out.
So after all that, I now have front and rear plates attached to the car:
and the rear:
