thx guys!
Dziku wrote: the car is totaly freak and awsome...
keep in mind engine transplant and the mod's i did along that process was only stage 1 of the entire operation, so no time for a real celebration yet, no where near finished at all! but i do think it allready drives totaly freak and awsome
yesterday was my first drive on wet tarmac without rain since the engine transplant, after engine was warm i wanted to make some speed, i pulled up from first gear, shifted at 3500rpm then did full throttle in second gear and he did a full rolling burnout!! i threw flames out of the exhaust hitting the revlimiter when drifting a roundabout; very cool noise and sound that was
then next came a roundabout with a long S bend after it wich i drifted all the way, even changed from 2nd to 3rd gear while the switch took place in the s-bend.
today on dry i tryed the same trick as yesterday, pullup in first, shift at 3500 rpm and then full throttle in second and he did a rolling burnout AGAIN!!!
and that was with the wheels frome above with 195 wide tyres at normal pressure
the car feels and handles so balanced and good that i allready dare to drive it like this, even though i'm definatly not used to all this power under the right foot, it drives like a maniac. and even then i'm still planning to put at least 200bhp on the rear wheels with this engine!
i definatly need to finish the exhaust, waiting for stainless steel parts at the moment. after the exhaust is under and the extreme noise is controled with the y-valve i think i'm brave enough to drive it through the whole country and do some mileage, the engine still needs to be handled extra carefully since the refurbishment "woops"
