I spent another couple hours on this tonight, sorting out more wiring BS.
Starting with a look at the relays.
I found some information and diagrams relating to the relay locations on SwedishBricks forum earlier, although my setup is still different. lol
As standard.
Simplified somewhat.
Excuse the blurry pics, dunno why this one is diplaying so large!
As can be seen, only one relay is required for the engine to run. I assume I'm right in marking this as controlling the fuel injection. The car dies as soon as it removes, and obviosuly won't fire up without it.
Going from the above diagram I am thinking the relays are layed out like:
Top row (left to right)
Bulb failure
Unused
Wipers?
Unsure
Middle row:
Fuel injection
the only one required
Fogs?
Flasher?
Empty (no pins)
Unused
Bottom row:
EW?
CL?
Unsure
Aux lights
Rear fog
Who knows though. Can anyone confirm this and explain the others?
Here's a close up of the ones removed if it will help ID them.
I then started chasing back and stripping out unrequired parts of the loom. SRS, seatbelt pretensioners, radio, seat heat, N/S/F door, spare plugs etc.
I am only working on one side of the loom atm and some of them loop to the other side so the rest will be removed when I get to that side.
Tonights removal. it doesn't look much in that image but there is a fair bit there, nothing compared to what is still to come out though.
Much less cluttered FTW.
As can be seen above, there is an ECU in my rubbish pile now (Bosch 0227 400 219). This is for the ABS. I have no idea why it didn't want to run the other day with it unplugged though lol. I can 100% confirm it is not needed though.
I should have trusted my judgement when working out which one it is. Failing that, it says something like Made in USA on it, as does the ABS pump.
Another massive plug and bunch of wires soon for the chop (ABS)
The wiring removed so far is surprisingly heavy (only because I never realised how much there was lol)
I had a head scratching moment earlier too. I was 100% confident of the items I was removing, so took a good few out and then tried to start the car - nothing!
The transponder chip pick up on the barrel had came unplugged lol. Happy days.
Shame I only had a couple hours for it, but it's the weekend soon and then two weeks holidays.
