Hi everyone. In november i bought myself a low mileage 850R Auto saloon with blown headgasket to become my new daily and a quick build project. With the biggest single mod to convert it to AWD using the AWD system from an 850 AWD estate doner and at the same time complete the manual swap. Reason for the conversion is i really dont do Auto or wrong wheel drive.....
I also managed to come accross a pair of compomotive MO6's in 18 x 8 fitment to go with the pair i already had. Unfortunately they were the incorrect offset for the 850 so i needed spacers. So instead of going for the expensive extended wheel bolt option, i decided to convert the car to wheel studs and nuts instead as i hate wheel bolts anyway. I also upgraded it to the 302mm discs.
I also decided a small head unit upgrade was on the cards as i wanted iphone feedback. Because of using the single din ALpine unit i wanted to fill the space with something other than a radio pocket so i made a gauge panel using a set of VAG VDO gauges which will also give me nice engine readings too.
In early February i picked up my doner AWD which looks a state but has all the parts i need on it and a fairly low mileage again. I got the car from my local breakers yard hence the knackered roof. The car drove into the yard and the prop was still all connected so i cannot see why there will be any problems with the running gear.
Cheers Adam
