Page 5 of 7
Posted: 11 Aug 2015 05:49 pm
by zack360
Yeeeepp!!
by derskine
bogbasic wrote:Yo, direct is best and that'll save two hundred miles if you consider it would have to go all the way back to Brum if it came down to me first...
:mrgreen:
Posted: 12 Aug 2015 12:00 am
by zack360
Good morning people..things are going it's way for now..meter surround checked, indicator cover checked, agent checked..only payment yet to be made..I haven't checked with stevep..on the indicator price..or it has no price tag on it.. :wink: ..
Best wishes
Zack
Posted: 16 Aug 2015 12:45 am
by zack360
Hello derskine, i've PM you the address, please note I did not include the place name it's Birmingham Best Inn..put that right after the room number.
Mucho Gracias..
Zack
Posted: 18 Aug 2015 09:37 am
by zack360
This is the piston that the foundry did. Scrapped of the rust on the edge of the caliper, and it fits perfectly..
Posted: 27 Aug 2015 07:04 am
by zack360
Hello chaps..
A little update..modified brake hose. Made from flame resistant material..hose is suitable for all types of oil and fuel..but the caliper side nut is slightly longer..i think it won't do no harm. Now..all left is to asseble it back..
Posted: 27 Aug 2015 08:01 am
by zack360
Group purchase allowed..
8) zack360
Posted: 31 Aug 2015 04:47 am
by zack360
Hello all, quick question, can I replace left hand side brake calliper with right hand side? The only difference is the brake hose hole..it will face backward.
Thanks
Posted: 31 Aug 2015 07:44 am
by Joris
zack360 wrote:Hello all, quick question, can I replace left hand side brake calliper with right hand side? The only difference is the brake hose hole..it will face backward.
Thanks
No you can not. Try bleeding one when the bleednipple is on the bottom.
Posted: 31 Aug 2015 05:25 pm
The flexi pipe will need to be longer as it will point out towards the ground at the bottom of the caliper. You could bleed it the right way up then assemble it on the car. The pipe would have to be done up first to get it positioned right, then the caliper removed, then bled making sure the pistons don't come out.
I don't know if heat percolation in the fluid is important, but that would be affected.
Overall not worth the hassel or risk.
Posted: 31 Aug 2015 06:16 pm
by zack360
The bleed nipple is so darn hard to get..i sent the l/h side brake calliper to foundry and ask them to remove the broken bleed nipple..he did remove it and make a new thread..he make it bigger. Actually I already acquired another brake calliper but it's for the r/h side. I'll just keep it for future use.
Thanks for the info man.
Posted: 31 Aug 2015 06:20 pm
by zack360
Flexi hose fitted..
Posted: 01 Sep 2015 02:56 pm
by bogbasic
Wicked work, man - I have lots of issues with nipples, too ;-0 ;-0 ;-0 ;-0
Posted: 24 Sep 2015 04:24 am
by zack360
Next project is to clean the fuel tank. This is what a dirty tank will do to your carb.
Posted: 27 Sep 2015 04:12 am
by zack360
Hello experts of 360,
Now the carburettor is clean. I am going to remove the fuel tank. From Haynes manual, 1. I must jacked up the rear of the car.-done-.2. Remove the heat shield from beneath the fuel tank.- I don't have the heat shield, it's carburatoer. 3. Disconnect the gearchange rod at the gearbox and unbolt gearchange from the middle of the torque tube. How do I do this?
