Nolan's 340 pick up D-project F7p (need help for Vss)
Nolan
Re: Nolan's 340 pick up D-project F7p (need help for Vss)
Post by Nolan » 29 Jun 2015 10:49 pm
Comme je peux en essayant de chopper les infos à droite à gauche :lol: :wink:
Joris
Post by Joris » 30 Jun 2015 12:08 pm
Looking at you pictures, why does the idle air valve have a airfilter on it? It should regulate the amount of air going around the throttleplate at idle.
Nolan
Post by Nolan » 01 Jul 2015 05:17 pm
I saw this anywhere like that, but don't know how it was mounted before!
Post by Ride_on » 01 Jul 2015 07:46 pm
The high rpm won't be because of the lack of vss otherwise it will go mad every time you stop. Seems you are letting in air via the idle valve.
Anyway I am interested as to what you have done with the tank, have you used a 360 tank in a 340? How are you getting fuel out of the tank? Is it a tank from an injection model?
Nolan
Post by Nolan » 01 Jul 2015 08:53 pm
Hi, i need to connect the last water sensor to 32 & 15 on Ecu, i think that's why the engine idles like that... but you think it's because of the idle air valve?
The tank is the original, placed on top, i've used an external Bosh 044 Fuel pump and new hoses!
Post by Ride_on » 01 Jul 2015 09:43 pm
Just going on what the others are saying, I'm not knowledgeable on this engine. Wouldn't be good on an LH2.4.
So the underside photo just didn't have the tank in? If you are trying to suck put of the top of the tank you may have a problem, its not designed to do that especially if you are using the original carb feed pipes in the top. The 360 injection feeds out of the bottom of the tank with a 12mm pipe feed, other cars use an in-tank pump. Others have tried using the 2*8mm pipe lob joiners at the bottom of the 360 carb tank and it didn't work.
Still, seems to working well enough to discover idle problems, but you may get intermittent fuel pressure.
Nolan
Post by Nolan » 01 Jul 2015 10:59 pm
The original tank (340) was placed in the "trunk"! I don't use original hoses, just a reducer from tank to 8mm (in) injection hoses...
Maybe i need another fuel pressure regulator than the original f7p one? But i just need 3b pressure!
Post by Ride_on » 02 Jul 2015 02:27 am
It's nothing to do with the regulator, I think the explanation is that the pump cavitates like propeller driving too hard because it can't get fuel from the tank quickly enough. It needs a large inlet to the pump assisted by gravity or an internal lift pump. Simplest solution is to fit an in-tank pump.
Basically its hard to make a pump that sucks well and produces injection pressure.
Post by Chris_C » 02 Jul 2015 04:51 pm
Certainly one of your idle problems is the idle solenoid. Mine was plumbed up exactly as you have it now, I took it to my MOT man and he (being a knowledgeable chap) said that it was a warped carb base being a 1.7. I said it wasn't a warped carb base, have a look under the bonnet, which he did and straight away saw the idle solenoid with the filter the same as you have it.
Long story short, he pulled off the filter and put his hand half over the "inlet" to the ICV. The revs went from fluctuating (literally revving itself a bit) around 2000-2500 to a steady 850.
I can't find a good photo of it, but take a hose from the manifold under the throttle position sensor plug in the photo
to the ICV, then another from the ICV to the hose between the air filter and the throttle body (easy to do if you have the original Renault hose)
There are other things it could also be, but it will never be right without doing that.
Speed sensor. The one I use requires a regulated 12V, not 5V, but there may be differing sensors available. Mine didn't come from a Golf. The housing is identical, it just screws in as you have yours. No other mods to the dashboard were required, just 12V in, GND and signal out to the ECU.
Nolan
Post by Nolan » 02 Jul 2015 06:13 pm
Hi, my speed sensor is from a Volvo 440 speedo, you think i just have to put a 12v on it? I did that before and it was the same problem...
I'm trying to understand the problem you mean with the solenoid, but can't find photos of the original mount... The icv is the red part?
Thx
Post by Chris_C » 03 Jul 2015 11:19 am
ICV = Idle control valve, the silver valve connected to the tiny filter here
That needs to be getting air from behind the main air filter, i.e. the air is partially vacuumed, not it's own filter. The red part is the throttle position sensor.
My speed sensor is also from a 440. I got my wiring directly from the 400 series green books (actually, may have been one of the green service bulletins I have, as I can't find it immediately in the pdf versions)
EDIT: Can't find any F7x specific photos atm, but look at all modern air filter hoses on eBay. All have a 'T' piece so that you can get air for the idle control valve e.g.
http://www.ebay.co.uk/itm/BRAND-NEW-AIR ... 1656851804
Post by Chris_C » 03 Jul 2015 11:31 am
Partly assembled
Ahhh, heres the other side!
Nolan
Post by Nolan » 04 Jul 2015 11:49 pm
Oh, i think i have connected the white sensor connection from icv to a water sensor which is on the left side from the water box (Renault 19), but not sure about this!
So i can let 12v on the Vss? 2 wires (module & ecu) are connected on a wire to vss
I need to find a T piece or do a hole in my air box hose!
Nolan
Post by Nolan » 05 Jul 2015 06:02 pm
I've done the connection with the Icv, now the engines idles better but a little high (i think about 1500/2000rpm)
And there's smoke and bubbles coming from the junction between the exhaust manifold and the cylinder head, but the temperature seems to be ok... ??
Nolan
Post by Nolan » 16 Jul 2015 11:25 pm
Little video from the engine:
https://www.youtube.com/watch?v=lSpEsGabghE
sm4
