86 340 engine swap
Chrisleev340
86 340 engine swap
Post by Chrisleev340 » 18 Jan 2017 09:34 pm
Anyone put a Clio 172 engine into a 340 I understand the wiring will be harder and sump will require modifiying anything else? Cheers
thododd
Re: 86 340 engine swap
Post by thododd » 30 Jan 2017 08:13 pm
Yep. Been done
Got any pics of your 'project'? Otherwise this ought to be in the engine section of the forum
Alex Laidlaw
Post by Alex Laidlaw » 11 Mar 2017 01:14 pm
I would expect the 172 engine may be too much for the 340 driveline, you have to be careful when driving any 300 hard, even the 1.4 can break the propshaft if you abuse it.
I've broken two, the first still with the 1.4 and learnt my lesson to be careful with wheelspin after that. With the F7P I've broken one and that was from not feathering the throttle over bumps/a small jump. The problem with trying to toughen up the prop is the problem can just be transferred into breaking the bell housing or gearbox input shaft.
