Volvo 343 Turbo!
Re: Volvo 343 Turbo!
Post by 340GLT » 12 Feb 2009 12:24 pm
Yeh john i spoke to them yesterday but iain put 6 clutches in from them and they wouldnt take the power. They want £310 for a paddle but between us, its made by helix motorsport as they sent iain one that they didnt change the box on.
I would try the fiat paddle centre to a turbo cover plate and 340 release bearing.
The other cover i would like to try is a diesel one. I do have one here, but as the cover is much thinner on the diesel because the flywheel is thicker i think you may have o shim the release bearing.
Ovlov 3.6L
Post by Ovlov 3.6L » 12 Feb 2009 07:19 pm
filthyjohn wrote:Techniclutch told me they'd sell an uprated organic centre plate for a 340 1.7 and that they'd supply it along with a clio williams uprated pressure plate. I'm pretty sure they'll make a paddle clutch for this application if there's someone with enough cash.
Hmmmm, allright...........and the last point, you told.............that's the most different part ;)
I think I'll gonna do it with the Centre plate of a Fiat Uno............
Post by filthyjohn » 13 Feb 2009 02:13 pm
So the ultimate solution is a paddle direct from helix, with some sort of uprated williams pressure plate. www.williamsclio.co.uk is quite good for renault tuning, they were quite helpful when I asked about carb manifolds and there are enough properly tuned cars on there too.
Ovlov 3.6L
Post by Ovlov 3.6L » 14 Feb 2009 03:35 pm
filthyjohn wrote:So the ultimate solution is a paddle direct from helix, with some sort of uprated williams pressure plate. http://www.williamsclio.co.uk is quite good for renault tuning, they were quite helpful when I asked about carb manifolds and there are enough properly tuned cars on there too.
But the main-question is: Will the splines of the helix paddle fit onto the axis of the coupling-housing of the 340 1.7? I don't think so because Renault uses other splines.......
What is the ultimate solution, I think: A paddle clutch of Fiat and a pressure-plate of helix.
But will the dowel-pins on the V460 fit directly to the pressure-plate of Helix?
Post by filthyjohn » 15 Feb 2009 10:37 pm
Ovlov 3.6L wrote:Will the splines of the helix paddle fit onto the axis of the coupling-housing of the 340 1.7?
I believe it will fit, i think that was Iain (huskyracer)'s setup. It was a paddle made specifically to fit the 1.7 clutch shaft.
Ovlov 3.6L
Post by Ovlov 3.6L » 16 Mar 2009 05:54 pm
I just called and mailed Helix Autosports a few times.
They can deliver me a uprated pressureplate which fits on the flywheel.
The drive-plate seems to be a problem. They told me that the splines of the Volvo 340 is different from that of all the Fiats......... :shock:
I'm sure they aren't right, so I send them another e-mail that most splines of Fiat are the same of that of Volvo 340.
After that, I didn't get an answer.........
Pffff, why does I can't get any easier........
Ovlov 3.6L
Post by Ovlov 3.6L » 28 Apr 2009 09:52 pm
finally some weeks ago I found the right solution for my clutchproblem.
Helix has put en complete clutch together for me.
- A upgraded cerametallic drive-plate
- A upgraded clutch-cover
All together it will cost me 458 pounds................quitte expensive but I need it.
The only problem I've got now, is to pay it........
The next problem will be te prop-shaft.......
At this weekend I broke one while drifting @ the Circuit of Zandvoort :wink:
Post by filthyjohn » 29 Apr 2009 01:55 am
Let us know how well it handles the power will you? At least now we know Helix have heard of the 340, and can be persuaded to make bits for it.
nsmdm
Post by nsmdm » 28 Mar 2011 11:31 pm
what gearbox did you use?
where did you get the steel prophaft?
Ovlov 3.6L
Post by Ovlov 3.6L » 14 May 2011 06:59 pm
About the clutch; I mounted it about one and a half year ago and I must say; thats the last time I bought Helix. The pressplate is good. But the splines of the drive-plate has to much clearance. And You can hear it very well while idling.........*taktaktaktaktak*
Well uhm, the propshafts of RecoProp were just rubbish. I had to send them 5 times back to them because it had een balance-problem which caused big vibration problems.
Now I made my own propshaft. I started with that of a Volvo 244. Made it shorter. Made some adapter-plates. Total costs (including new bearing etc) about 40 pounds. The balancing I did on my own (with much patience)........... And costed me almost nothing (about 1 pound). I think this propshaft can handle 250bhp without problems.
The gearbox is completely standard. I should handle about 230bhp without much problems (no clutchkickin' allowed ;))
At this moment I'm upgrading the "machine".
- Home made spaghetti-exhaus-manifold
- T3 turbo form a cosworth
- big front mount intercooler
- 2.0 liter inlet manifold
- 65mm throttlebody
- 3 inch exhaust
- some bigger injectors
- B18EP camshaft
But still the stock-motorblock
So lets see what we can get out of it ;)
Post by volvodspec » 14 May 2011 07:05 pm
Buijs, this thread needs a fresh set of pics!!! :mrgreen:
Ovlov 3.6L
Post by Ovlov 3.6L » 18 Aug 2011 08:55 pm
Just some pictures (finally):
Bigger (modified) intercooler
2.0L inlet manifold. It has longer runners and bigger diameter.
Solid engine-mounts
Cosworth turbo with 3 inch exhaust
Home-made exhaust manifold, together with the cossie-turbo
Mounted it and heatwrapped it.
Bigass intercoolah!
B18E camshaft
Some bigger injectors
Painted it putted in a cage.
to be continued.......
Post by volvodspec » 18 Aug 2011 09:08 pm
^^ mr Buijs wants to keep up with my 1.4 turbo :lol:
Ovlov 3.6L
Post by Ovlov 3.6L » 18 Aug 2011 09:22 pm
You didn't see my last goodies yet :)
Please have patience for that.....
At this moment I'm stil busy with expanding the front wheel fenders.
Want to put on some 280-13" ;)
Intercoolerpiping is ordered and Buijs is still waiting for it.....
Post by volvodspec » 18 Aug 2011 09:43 pm
you ain't scaring me, i'm also diggin deep and very busy with upgrades :lol:
no worries bud, how 'bout a little twindrifting soon once you get er rolling sm4
