Coilovers can be acquired from GAZ, you send them your standard struts, and they convert them to coilovers and shorten them to allow you to lower the car.
Thomas.............
one wheel further back than otherside? (pics)
Re: one wheel further back than otherside? (pics)
The question is why would you want coilovers?
I've seen a lot fitted but not a single one that has had teh corner weights set removing the only usefull function of the coil over.
They dont want them for setting the car up Dai, they want them so they can go lower
Messem, fessem, old git grumble etc
They're custom ones made by GAZ Shocks mate, just give them a ring and send them your old struts
mines a lot better on coilies regardless of set up on a corner weighting machine. I have far more front end grip now, and very little understeer. I was running chopped springs previously though, so you cant get much worse
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Your problem would have been quickly and easily solved by fitting correct springs for aplication.
It does seem to be the DW way. Chop the springs then find out its shit so teh answer has to be coilovers. I would offer coilovers but as no one actualy wants to set them up to work there is no point in running comprised springs.
