Hot brakes.
Have a look here too:
https://sslrelay.com/buypartsby.co.uk/d ... ordID=5731
Unknown make (sounds like they just convert standard discs), but are a bit cheaper. If I stick with standard discs I'll probably try a pair of these.
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Why bother with the drilleddiscs...it only makes them worse.....less heat capacity, more prone to cracking. Porsche uses them to some effect, but those are cast with the holes in them, which is a lot better than drilling perfectly good discs. I run slotted discs on my track 360, but it did really well on the regular plain discs as well (just wore those down due to worn out brakepads). Slotted helps prevent glazing of the pads, but good pads wont glaze over that fast anyway, so you might wonder if the rapidly increased wear on your brakepads is something your ok with.
BTW, I wonder if spacers can be made for the girlings as well.. they are split down the middle, but I havent seen that kind of modification on these calipers before.
For those that might be interestedin 240 calipers: I found some on ebay for about 80 dollars (incl shipping from the US...by boat). They are professionally remanufactured calipers, completely loaded with pads and shims etc.
We'll have to find some disc that will work with them though.
I can't help thinking something is wrong if your brakes are getting that hot with road use...unless you're driving down a mountain on the way home
Both of my 300s have pretty good brakes, and the closest I've got to cooking them was following a 20 minute thrash over the cat and fiddle (twisting moorland pass) in the 360 doing constant 20-60(+)-20 pulls...and they were just starting to feel a bit weaker than usual by the end of it. Unless you're in that sort of territory, I suggest a hearty bout of 'stage zero' before you look at an upgrade.
I'm totaly with James on this. 300 brakes are quite good for road use.
The problem with fitting 240 calipers is the disk would need to move back about 20mm for it to alighn up.
http://www.ecs.soton.ac.uk/~clc202/brakes/index.htm
It can be done... somehow, on stock calipers. Cheers for the heads up on the PCD front Adam, the plan I had doesn't look like it will work then
Yeah, that was one one my cars, problem is I had to scrap it a while ago, and didn't have time to get the disc's off of it before it went. The calipers are stock, I took one off and offered it up against my 1.4's, they were the same.
Intresting thing Steve pointed out, is the 340 style ARB... thats a very very late 360GLT.
Dalahare - Yeah, that might well do it
Chris - I think it had early struts swapped on at some point - later 360s had the 'to strut' ARB mounting....earlier ones had the 'to wishbone' 340 type. Oh, and muppet for not pulling the discs
Chris - proper muppet
The problem with the 240 calipers are to get the centred on the disc the are in line with the mounting lugs. If you are fitting a much bigger dia disc you could make an adaptor to kcik it out further away from the hub centre.
Would these be suitable for stock caliper?
http://cgi.ebay.co.uk/OMP-246mm-Brake-D ... dZViewItem
Perhaps one of the brake experts can advise
I have had the brakes of a 340 on fire on a single-track road here (3 stops from about 100 in a few minutes).
The back plates have already been mentioned. Some pr1cks have those brake dust guards: DONT DO IT. Regarding wheels, in my opinion, even the steel wheels vent well enough. Getting the air to them and keeping the brakes working at high temperatures is where you can make a difference. High temperature pads and air hoses from the front valence.
Make absolutely certain your rear brakes are in top condition so that they do some of the work!
If I remeber correctly the twin pot 340 caliper is fixed - 1 piston each side. If that is the case the twin pot gives no more clamping force than a single pistion sliding caliper of the same piston size.340cbr wrote:From what years are the 340's that have twin pot calipers.
Some time ago I have tried to fit front disks from a 440 Turbo, but with no success.
Still got all the pieces.
