Rear lowering blocks.
If you want to raise the rear end then you would need to turn the axle around so it is mounted below the springs.
Speaking of lowering blocks, I might have to have a natter to you Dai about getting some for Nessy. That thing must have THE most un-sagged rear springs I've even seen on a 300, which makes it all the more wierd why the front is so badly sagged.
The front end does seem to get it worse on a 3. The oposit to the 2's and 7's!!
danielvanderwoude
The best way to get the bolts out is to undo the end of the drive shaft.
I can ship to Holland no problems. Would porobably be best if you were also wanting other parts.
Josh_Cohen
dai
hi dai cam u get back to me about some lowering block and some fron springs for my 340 i wanted to go about 100mm can u give me a price cheers josh
New User Long Time Lover Of Volvo 300's
I'll drop you a Pm
