Brake upgrade Project (Disks all round) Completed!!
Japper
Post by Japper » 17 Dec 2005 01:37 pm
Can anyone's car lock the rears on tarmac using the handbrake?
Easily. I only hear two clicks when I handbrake in the parking. It doesn't take much effort to let it slide on the handbrake either.
Leather, leccy windows and mirrors, snowcap, foglights, open air filter, black roof upholstery. What more do you want? >a 2.3 turbo!
340 Nate
Post by 340 Nate » 17 Dec 2005 04:38 pm
340GLT wrote:Its inside the drums at the back spread between the pads!!
cheers mate, thought it might have been those cylinder things inside the drum but never knew the technical terms :o
Nate
Ronnie
Post by Ronnie » 20 Dec 2005 09:53 pm
foggyjames wrote:Can anyone's car lock the rears on tarmac using the handbrake? Neither of mine can...?
Mine neither - and that's with new rear cylinders and shoes.
Is this a 340 vs 360 thing - or am I just not showing enough comitment to the death slide?
http://www.filterfeeder.eu
Post by foggyjames » 21 Dec 2005 01:17 am
This is definitely wierd...my car seems to have uber brakes (for stock), yet I can't lock it up on the handbrake.
Post by petefarrell360 » 21 Dec 2005 02:20 am
Handbrake turn? Steer from the rear with the power!
Sirnixalot
Post by Sirnixalot » 21 Dec 2005 05:20 pm
VERY interesting development. You've inspired me to plan something similar. Might try using integra type r calipers as they have quite a good pad selection.
Are you planning on upgrading the master cylinder? If so to which one?
Also im guessing you will probably want to try a brake bias adjuster or proportioning valve.
Post by 340GLT » 21 Dec 2005 07:11 pm
I'm gonna run on the standard master cylinder to start with to see what happens, and the same with the biasing valve. I read on converting a 240 to V70R brakes and calipers you use the pressure valve from the front at the back to even things out, so this is an option.
Cheers Adam
Post by 340GLT » 02 Feb 2006 09:03 pm
Been doing a lot of work Re this recently but was having probs with the caliper mounting!!! Must thank Bilbo for posting the 240 caliper mounting holes!!!! Anyway a bit gutting i dint go with my first thought of the 240 ones ages ago. But anyway i should have the front setup in a complete sort of state by sunday!!!
Cheers Adam
Bilbo
Post by Bilbo » 02 Feb 2006 11:22 pm
well we did many 180's when we wrong slotted the other night on single track roads and the rally car with hydro handbrake will lock em in any conditions and at any speed. unless my bro drives :lol: .the button is reversed so if you want it to stay on you press button...ie if you just pull it ,it doesnt stay up, but his mind tells him to press button and then the car stalls :)
Post by 340GLT » 02 Feb 2006 11:25 pm
lol
Cheers Adam
alistairolsen
Post by alistairolsen » 03 Mar 2006 12:08 am
whats the story with bolting the calipers on? i assume you need some form of adaptor plate, but this will throw the caliper outwards. is there room for this?
To get the caliper to line up with the disk, doe it have to sit against the mount on the strut, or do you need a spacer?
Cheers, Al.
Post by 340GLT » 03 Mar 2006 12:12 am
Its all a real PITA TBH mate and the hub had to be machined to give me any space to mount the caliper behind on the strut, the brackets will make the caliper run in line with the original, if you move this you will seriously upset the balance and unsprung weight of the car and to solve this i am trying to get my hands on some ally 4pots!!! Poss RX7 like the ones on ebay at the mo!!
Cheers Adam
willowdog
Post by willowdog » 03 Mar 2006 09:36 am
I usually only have one click. Two and the rears are not going anywhere.
Funny thing is, I have the opposite to Foggy. The brakes are nothing special (compared to the 245 or my Skyline) but the handbrake locks on like pit-bull!!
Post by 340GLT » 23 May 2006 01:38 am
Well guys its late and i have been busy finishing this project off, the front will definately be using 280mm disks and impreza turbo calipers, they will also squeeze inside a volvo 15" rim. You couldnt get bigger caliper and brake setup inside a 15 if you tried, i swear!!!!
I will post pics when i get a chance as its now 99% done.
Although not on the car itself yet, on doner strut and rear axle.
If all goes well, may make some new lines up and bolt it all on on sunday!!!
Carl
Post by Carl » 23 May 2006 07:59 am
Good work. I'll give ya fifty quid for them :)
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
