Soo the wheel came loose while i was driving and it came off and snapped one of the studs
Volvo dont make them anymore and i dont know where to get some :/
Anyone know where to get some or where to get alternative ones that are the same??
Regards Jordan
Wheel stud snapped!!
Re: Wheel stud snapped!!
Subaru ones off ebay, they are longer but you can cut them down
Front or rear?
Rear is a wheel bearing change requirement aswell, as you need to destroy the wheel bearing to remove the flange. Definately for the later type, not sure about multipiece bearings.
Front might be simpler to get a replacement hub, same applies to rear, but you need the hub/flange and backplate all together if you want to avoid rear wheel bearing change.
Its a front one ! getting parts for these is harder than finding a pot of gold at the end of a rainbow :L
It's not that hard, you just have to put some thought into it. The only thing that we don't have a lot of is panels.
