Hi all, got my 3inch blocks on now, and having the same problem as everyone else with the anti tramp bar. Will it fit if i tighten it up with the car on the ground, or have i got to shorten it? if i've got to shorten it, has anyone done it and how much did you shorten it by to save me some time?
Any other ideas? Its fully loosened, both ends.
Thomas................
3inch lowering blocks + anti tramp bar
Re: 3inch lowering blocks + anti tramp bar
Thought you knew evrything tom?? lol
You can use it the length that it is. but the axel has to have the weight init, or do what a few other skid guys have done, cut it in half, take about an inch and a half out, weld a nut onto each cut part, get a threaded stud and basically make yourself a adjustable anti tramp bar...
if that makes sence...
You should know me by now, course i doDanYellowHeadlights wrote:Thought you knew evrything tom?? lol
Cheers, got it all sorted now. got the car up in the air and put the axle stands under the axle, someone sat in the boot, jack under the tyre to jack the axle up and in it went
Thanks, Thomas....................
you will feel it pushing against the chassis when you go over bumps on that side, mine does it and makes awful noises sometimes im only on 2" blocks atm. but hasnt fallen off yet so its all good!
Anti tramp bar. is that the one on the rhs rear but isn't on the Lhs?
Own:
86 360GLT
97 S90
92 960S, Royal
01 Subaru Lancaster 6
96 Volvo 854R
Owned
E90 320 M-sport wagon
S60T -Mazda Familia
850lpt -AU Falcon
855T5 -91, 95, 97 960
940TIC -Mitsi GTO TT
16x 360-Toyota corolla
Toyota corona-R32 Skyline
V70R -V70T5
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
Indeed it isLogan360 wrote:Anti tramp bar. is that the one on the rhs rear but isn't on the Lhs?
