is a 340 front subframe/front suspension crossmember/Front axle member (what ever its called) the same as a 360? managed to snap mine
i know were theres a 340 for parts so if it will fit it could save me alot of time and coin
340 subframe/front suspension crossmember on a 360
Re: 340 subframe/front suspension crossmember on a 360
how did you do that, hit something?
yes they are the same, only difference is the rear engine mounting brackets of a 340 that are bolted on; they simply bolt off.
was on track drifting and i span out, i didnt hit anything and there was no bangs or bumps etc but when it came to the next corner it was pulling towards the wall, must have been going for a while and that just finished it off, now i think about it i have been saying something didnt feel rite for a while but could never find anything,
cheers that's good to know will get on it asap
when you find a replacement maybe look into this: http://www.volvo300mania.com/forum-uk/v ... e&start=15
Would stop it happening again maybe? Although i'd guess that it's just been rusting with age rather than a defect in design, but still, worth doing
thats strange because thats more or less what was in my head apart from welding up the original seams, cheers foe the link mate not seen that beforeNimminz wrote:when you find a replacement maybe look into this: http://www.volvo300mania.com/forum-uk/v ... e&start=15
