Knocking noise on rear axle
Mcglone7
Post by Mcglone7 » 07 Sep 2013 12:52 pm
Hey,
I've got a knocking noise from the rear axle, i think it might be the metal rod that connects the axle to the chassis? Torque arm is it? Pretty much the knocking comes from the back right rear. Had a search about and can't really find any. Does anyone know who can supplies that part?
Also only started happening about 2 weeks after i lowered the car.
Cheers.
Re: Knocking noise on rear axle
Post by volvodspec » 07 Sep 2013 07:34 pm
it's not likely that the knocking is from that rod (commonly known as the anti-tramp bar on here)
prime suspect is the rear jacking point being able to touch the leafspring, that happens quite often.
also, if you lowered it quite a bit it might be the shock absorber that catches on the axle
Mcglone7
Post by Mcglone7 » 08 Sep 2013 04:39 pm
Oh thanks for that!
I'll have a look and see if can sort that out. Only lowered it by 2 inches, but got adjustable dampers coming anyway.
Post by Ride_on » 08 Sep 2013 06:08 pm
Its not common to fail but the rear radius arm could be responsible if its loose. Is it knocking when the back end goes up or down? Could be the bush is gone or the retaining bolt is loose. Its a small bolt in a big hole, if its not tight the rod will bang hack and forwards.
The rod is to keep the axle flat and maintain the camber and toe-in as the suspension goes up and down.
Mcglone7
Post by Mcglone7 » 09 Sep 2013 10:11 pm
It only ever happens when i turn right like hard or something then you hear a big knock. Then it continues knocking like quietly for a bit then goes away.
Post by macplaxton » 09 Sep 2013 10:17 pm
Zorst?
alf
Post by alf » 11 Sep 2013 08:23 am
+ 1, it happened to me on the left side, but I had a horrible squeak on poor roads.
the early bird gets the worm
