Handbrake spring cup
Hello all, while I was dismantling my rear axle I undid the hand brake cable in the process the little plastic spring cup decided to fly off very fast and lose itself.
Does anyone have a spare one of these?
Thank you
Ben
Thank you
Ben
Re: Handbrake spring cup
Hello Ralf,ralf850gle wrote:Hi,
you may order these:
http://www.volvo340onderdelen.nl/produc ... 105b10cb23
Regards
Ralf
Thank you, I'll order these soon, there is a lot on this site I would like, do you run/own this site?
Are larger items OK for postage to the UK?
Ben
Hi,
no, I just found the link and ordered some of the parts.
But I ordered some parts and they delivered really fast.
Regards
Ralf
Regards
Ralf
I can vouch for the seller as well! Very helpful, very quick, postage a little steep but you can't have everything
If someone wanted to do a scribble with the important dimensions I could draw it up for 3D printing.
You took the words out of my mouth! I was thinking of doing this part but i was worried about the shear strain on it.Ride_on wrote:If someone wanted to do a scribble with the important dimensions I could draw it up for 3D printing.
Do you have a 3D printer, i have just sent some CAD drawings of to be printed.
Ben
Just for everyone elses benefit, these days once you have a solid file (STL) you can use any of thousands of printers on-line for a few quid a go. Something like this would cost about 50p per unit in PLA + GBP2.50 setup charge. Whether PLA would be strong enough I don't know, but I can't break it with fingers. Cable might wear through eventually.
Tinkercad is a good place to start, everything can be created from there to do your design and share it. This then links to a hub service like 3Dhubs. You can download to 3Dhubs directly if your have generated your design elsewhere.
Hi,
just another idea...
I used the spring holder washer from the brake shoes rear and a plane washer just a little more in diameter.
Then cut into both from side to center with a 1mm disc with a grinder...
Think this would do....
The deepening in the upper part centers the spring and will not allow the cable to come loose.
Regards
Ralf
Regards
Ralf
Good idea!ralf850gle wrote:Hi,
Regards
Ralf
