[340 1.6D 1986] Front coil springs...
mike340
Post by mike340 » 10 May 2017 12:28 pm
Hi all,
I am tirelessly looking for new coil springs replacement for my Volvo (5-door 1.6D 54HP 1986), but it is extremely difficult to obtain springs designated as suitable for my car. I would like to learn if there are any cars which are still continued in terms of spare parts and whose coil springs would match these of my Volvo. The parameters I have found in some V3M pdf are:
  • free length: 367mm
    no. of coils: 6.5
    wire diameter: 11.0mm
    coil diameter: 116mm
I have found replacement coil springs to have a parameter of AA (whatever it means, I dunno).
Does anybody of you have any ideas?
360beast
Re: [340 1.6D 1986] Front coil springs...
Post by 360beast » 10 May 2017 06:18 pm
I would have thought standard petrol 340 springs would do or 360 springs. I would wait for someone with more knowledge on the subject to add their two pence first though.
benji1985
Post by benji1985 » 10 May 2017 10:10 pm
I got new springs from eBay, melay
Ben
benji1985
Post by benji1985 » 10 May 2017 10:11 pm
Post by classicswede » 11 May 2017 10:25 pm
benji1985 wrote:Look at this on eBay http://www.ebay.de/itm/331522859772
what are the for? It says D16, B19 343 and 345 all of which did not have the exact same springs.
I have new production GLT springs that would be a reasonable option to use
mike340
Post by mike340 » 13 May 2017 10:29 am
I appreciate the efforts of all of you, but, like classicswede said, there are differences between models.. I know that mine needs at least one pigtail-type end of coil spring.
Post by classicswede » 15 May 2017 10:49 am
mike340 wrote:I appreciate the efforts of all of you, but, like classicswede said, there are differences between models.. I know that mine needs at least one pigtail-type end of coil spring.
I'm not aware of any model ever having a pig tail end, are you sure?
mike340
Post by mike340 » 16 May 2017 08:14 pm
classicswede wrote: I'm not aware of any model ever having a pig tail end, are you sure?
Thank you for making me reconsider it... I had mistakenly convinced myself somehow that there was a pigtail end, when in fact there was not any.
What parameters are the GLT springs you had mentioned? Would it be a problem for you to send it to Poland?
Here is one of the PDFs that I have found during my research:
http://www.proparts.se/dokument/bibliot ... _VOLVO.pdf
Indeed, the coil spring has got `plain` circular ends. The thing is, I come from Poland and while the springs' price may be bearable, I don't entertain the idea of paying as much for shipping. I will contact that Swedish shop for their price.
Post by classicswede » 17 May 2017 09:23 am
these are the spring details I have
Whilst the GLT spring is shorter it is stiffer so only rides a little lower. It would be a good upgrade to slightly firm up the very undersprung front end
Shipping to Poland would be £23
mike340
Post by mike340 » 06 Jul 2017 01:06 pm
I have bought the springs from classicswede. The mechanic was hesitant to mount them, but noticed they were thicker, and the end result is satisfying.
However, the car is a bit lowered and I need to be careful with road bumps I did not use to care about when I had had the very original springs.
All in all, the springs for B200K can also be used in a Diesel variant.
