Front suspension very soft / bit low
Posted: 23 Mar 2020 12:35 pm
by major_slackr
Hiya,
The front suspension on my 340 looks a little low and feels very soft so looking for some advice and pointers please!
It easily hits the bump-stops over relatively minor bumps in the road, which is annoying and not going to do it any good as a daily on the roads round here... The dampers appear working as they stop after one depression but it all feels very soft. I am thinking it probably needs new springs but should the dampers be ok still? I have read changing the oil can firm them up a bit which would be nice... also if the springs need changing what are the options? Ideally don't want to spend a fortune on fully adjustable for front and rear if I don't have to, but I am looking to give the car nice solid (compliant but firm) handling for the road.
I see classic Swede does a wide range of dampers and springs but not sure whats best for the 340...
Cheers!
Re: Front suspension very soft / bit low
Posted: 24 Mar 2020 08:48 pm
by bogbasic
Hello, great looking car. I have just got new springs and damper inserts from Ebay and local spares shops but I am sure Dai at classicswede can advise.
Posted: 24 Mar 2020 11:16 pm
by 360beast
If you want to firm it up then look in to some new dampers and 1" lowering springs and blocks.
Posted: 25 Mar 2020 12:15 am
by bogbasic
When you do the swap you will be able to check the strut cups. Chances are one or both will need repairing - Dai does this too. My preference is for originality, rather than lowering, etc, but that's partly because mine are driven along a boggy track, or at least they were before we had to stay at home, arf!!
Posted: 27 Mar 2020 08:24 pm
by Tofufi
I was of the impression that 360 front springs are stiffer than 340 ones.
I've 360 front springs in my B230FT 340 and the front isn't massively soft.
Posted: 06 Apr 2020 07:00 am
by major_slackr
Thanks for the replies, ended up getting new shocks, 1" lowered front springs, bump-stops, top-mounts etc from Dai @ Classic Swede.
Fitted over the weekend and results are excellent :-) - coupled with the GAZ adjustable rear shocks it now drives like you would want it to! rear had sagged enough that it sits nice and flat, just a bit lower and looks really good.
