Front springs
Stuntman
Front springs
Post by Stuntman » 04 Feb 2006 08:12 pm
Hello again, I know I've been posting new threads alot but I really need some help.
I'm finding seperating the top nut ont the strut impossible, I've smashed 2 spanners today.
How difficult should this be, its the nut that you have to lock ant then turn the tread with another spanner.
Please help!!!
Erm, I've lost my keys again...
Post by bogbasic » 04 Feb 2006 09:29 pm
Is this the nut right at the very top of the strut under the bonnet. The nut I am thinking of is on the top of the shock absorber rod. The top of the rod is flattened on two sides so it can be held with a small spanner while the nut is undone. It should not be dreadfully tight unless someone has used an airtool or a setting threadlock!
Stuntman
Post by Stuntman » 04 Feb 2006 09:35 pm
Thats the bugger, I'm a strong bloke but for love now money I can't get this undone, It's so bloody tight!!!!
So whats the consensus, take it to a garage and let them undo it?
I think I may have to resort to this which is an arse really.
daffodil
Post by daffodil » 04 Feb 2006 10:24 pm
hi if you have some good mole grips you can hold the shock in between the springs....under the dust cover and then undo the nut
Post by classicswede » 05 Feb 2006 12:02 pm
The only way to do it is with an air impacter. If you nip down your local garage they should be able to loosen it for you.
Stuntman
Post by Stuntman » 05 Feb 2006 01:53 pm
First Job tomorrow Dai, I cant believe how many spanners I've broken!!
Post by classicswede » 05 Feb 2006 02:16 pm
Yep they are feckin tight!
