Dampers?
Re: Dampers?
http://www.volvo300mania.com/forum-uk/v ... r&start=15
Key words to note as you read the above; dampers, don't and stiffen.
What do you want the car for? On the plus side, over damped is better than oversprung. However, correct wins over both quite significantly.
Re: Dampers?
I had to refill my fronts when I found out that my gas cartridge dampers wouldn't fit. I used 10W/40 engine oil rather than 80W as suggested elsewhere. I did this because the oil I removed looked like 5W MTB fork oil, thin like water. However I haven't driven the frigging thing since then, so I can't say what it's like.
Re: Dampers?
Lets not get to tech lol
I just want ride quality with the 2'' drop my 340 has
How does the suspension feel with the 10w 40 in it does the body rock much?
Re: Dampers?
I'll let you know in about 5 days.filthyjohn wrote:I haven't driven the thing since then, so I can't say what it's like.
Re: Dampers?
im affraid its quite complex stuff..and needs to be spot on to be enjoyed otherwise ride wil be crap/dangerous.Cripvw wrote:Lets not get to tech lol
Volvo 340
1988
Re: Dampers?
Yes i know the technical bits ive been messing with spring rates, bound and rebound camber and toe for yearsgerm wrote:
All i want to know is what dampers to use on the rear of my 340 and are there better oils to use other than diff oil lol
Re: Dampers?
Spax adjustable krypton jobbies. Available from our very own classicswede.Cripvw wrote: All i want to know is what dampers to use on the rear of my 340
