340 front tie bar bushes
My front tie bar bushes are cracking. I have been told you cant get replacements. Do any other car make have similar. I would prefer rubber not poly as there are too many speed humps herabouts .
thanks, Steve
thanks, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
Re: 340 front tie bar bushes
Steve, do you mean the bushes in the tie rod ends? If so, the t/r/e themselves are relatively easy to source and are quite cheap!
Thats right ,they are at the end of the front tie bar. Last year the mot tester put on an advisory but implied they were unobtainable from Volvo(the local Volvo main dealer has closed down). Have you found them at a motor factors? Would like to replace them shortly so be most interested of your supplier.
Thanks, Steve
Thanks, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
I'd check Ebay first:
http://tinyurl.com/300tierodend
these ones are original Volvo (I can recommend the seller):
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0322497057
otherwise try searching for a part number like
TRW JTE338 (TRW made the original PAS racks for example, they might be good to try)
http://tinyurl.com/trwtierodend
QUINTON HAZELL QR1785S
http://tinyurl.com/qhtierodend
DELPHI TA770
http://tinyurl.com/delphitierodend
MONROE L2771
NK 5034803
... and many more ...
DELPHI TA770
MONROE L2771
NK 5034803
The problem with those Ebay links (all of them except volvo_et_vendo) is... they don't claim actually selling TRW (etc.) parts, just equivalent to OE part no. this, and TRW (etc.) part no. that. But the good thing is, you get a list of the fairly many types of cars that have the same tie rod ends as the 300 series. One more part that may be NLA at the Volvo dealer, but will definitely be available for a long long time to come.
Volvo 340DL Variomatic -89
Volvo 360GLT -86
Volvo 360GLT -86
We seem to be mixing description. Your links show what we call in english ,track rod ball joints . I am after the rubber cushions with holes that fix on the end of the front stabiliser bars!
thanks, Steve
thanks, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
Sorry, I thought tie bars / track rods were the same ...
Front stabilisor bars: do you mean something like this?
Just in case you do:
http://tinyurl.com/stabi
if it nis the 4 triangular bushes that you need volvo still had them about 6-7 month ago worth a try
Yes, they are triangular/conical. I found them listed under "nordic volvo" so looks like they are still available. So much for listening to the mot tester!
thanks, Steve
thanks, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
you cauld also get uprated like ive done from super flex they were only £26
OK, glad you found the right bits in the end!srtames wrote:Yes, they are triangular/conical. I found them listed under "nordic volvo" so looks like they are still available. So much for listening to the mot tester!
