speaker location on mk2 saloon
i have no stereo at all.. how and where do i mounth my speakers ive found the place on the rear shelf but what about front doors?
Re: speaker location on mk2 saloon
Which model year?
Up to 1982MY the speakers where fitted ahead of the doors in the side of the footwell. 83MY onwards had them in the front doors, but the old mounting positions remained, so you can still stick them down there if you want. Those cut-outs are for 6" x 4" speakers, but the Volvo speakers from around 80/81 (maybe earlier) were 4" round speakers in a 6" x 4" frame.
ok ill have a look. where can i get a dash bit for the headunit its elf?
83MY on you can get a fascia plate to fit a bog standard DIN sized unit. Same goes for the >82MY, but that is a different shape.
You need one of these
http://www.ebay.co.uk/itm/Volvo-340-360 ... 820wt_1270
A pair of these, which i have just installed in mine:
http://www.ebay.co.uk/itm/230644622380? ... 1439.l2649
A pair of these to cover those:
http://www.ebay.co.uk/itm/260840122524? ... 1439.l2649
And then a headunit of your choice
I've just put some of those 4x8's in mine, as i found the holes for them while i was installing the newer style speakers in the door cards, so now i have 4 speakers in the front haha all running from an old blaupunkt cassette radio, old school epicness
Here's some pictures i took of my ones:
Original volvo speakers in the door cards:
4x6's in the location under the dash with grilles over them. The holes already there on both sides, all you gotta do is screw the speakers to the metal
And together
Hope this helps! Thomas..............
And together
awesome! ill have a look at this then and get some ordered... ive got some 6x9 in little boxes ill dump in the boot to. i do not want to cut or drill anything into the mint saloon parcel shelf lol
p.s please tell me your sig isnt a photoshop
jamz wrote:p.s please tell me your sig isnt a photoshop
i think im going to get 15s with tiny tyres... 13s look too small if not low enough... im yet to see a pic of a car lowered on 3 inch blocks
Yh with 13's and low profile tyres you gotta get low!!!
Standard steels, 3inch blocks -
I only found those holes once I stripped the car and put it on the spit lol
Handy for a bit of music, shame they're not component sized.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Should have gone to SpecSaversL14MNP wrote:I only found those holes once I stripped the car and put it on the spit lol
That pic on 3 inch blocks does it cause exhaust problems
On the MK3 you can put various aftermarket speakers in the doors without modification, but may have to do away with the grill covering. I think the Mk 3 still has the kick panel location if you want to use that aswell, but possibly more prone to water damage.
The saloon parcel shelf is an excellent place for 6x9", but it is designed for a smaller round speaker recessed in a square. You will find a circular section to cut/push out. Cutting around the square is tricky to get to ovals in, use a template for the hole and bolt locations if the speaker come with one. My Alpines are 7x10" on the covers and cover the recess nicely, the bolts hold it well and the boot makes a good bass amplifier.
