Windshield washing fluid tank suddenly empties itself
sssu1
Post by sssu1 » 28 Jan 2017 07:01 pm
So my Volvo 340GL 1990 has a problem with the windshield washing fluid tank. After fully filling it with washing fluid and spraying some on the windshield 4-5 times, the tank suddenly empties itself. The fluid drains down towards the front of the car from under the tank.
Is there some switch or knob or something that I should close or turn or something, or is it just broken? While it is full it doesn't leak, and there are no visible cracks on the tank.
1990 1.7 Volvo 340GL — 68k driven
benji1985
Re: Windshield washing fluid tank suddenly empties itself
Post by benji1985 » 28 Jan 2017 10:47 pm
Seal on the pump?
Ben
Post by bogbasic » 29 Jan 2017 03:51 pm
Perhaps a hose connection has come loose.
Bests for now, bogs.
kennetr2
Post by kennetr2 » 30 Jan 2017 09:35 am
+1 on checking the pump to know if it went bad or not.
Spepper24
Post by Spepper24 » 09 Mar 2017 09:19 am
I had this recently, mine only emptied to the seal where the pump inserts into the tank so it was easy to find. I removed the pump, removed the small o-ring type seal. Sprayed clean with contact cleaner and applied silicon o-ring grease and reassembled, been fine ever since. give that a shot
1989 Volvo 360 GLT
