Kakemnstr
Post
by Kakemnstr » 09 Aug 2005 04:54 pm
hehe, apprichiate it
chris_c, see in your avatar that you also got the extra lights in the grille. do you have the original hella grille? or made it on your own?
mine looks pretty nice, but seems to point more up in the air... any tips how to get them to point a bit down (this is as the grille dont gow staight down) ?
Post
by jtbo » 09 Aug 2005 05:40 pm
There is also enviromental stress caused to car electrics, usually these will cause bad earth and these are potential car burners even with standard fuses, usually these are calculated into standard fuse sizes too so it should not take fire, but if problem is enough bad it can burn.
Then there is differences of 12V and 230V systems, powerloss etc. stuff, I have studied only 2 weeks electrics at school, but much more in this car hobby and there is quite suprising differencies. Also theory is just theory, in real life things tend to have ability to go wrong even if it should worked by theory
Volvo 343DL vario -81 -running-
Citroen ZX Dturbo -97 -daily-
Post
by Chris_C » 09 Aug 2005 11:11 pm
Mines the orig Hella one
I did have two but I sold one to someone else on V3M
The proper one has two screws that level the beam out, without seeing your lights, I won't be able to say I'm afraid, you might have adjusters, otherwise, you might have to 'modify' the mountings a bit! Good luck with it!
And Jani's points are spot on too.... you got the message yet and got hod of a relay and stuff??
Kakemnstr
Post
by Kakemnstr » 10 Aug 2005 12:48 am
got the message mate... could put in some new wires and extra fuses between the lights... if i bother
anyways, gonna head down to the scrap in the morning and get me a new starter, as changing wires and sparkplugs did not solve the problem (getting tired of pushing the car). i kind of miss that feeling i'v got from the 340 the first moths i had it, and from the old toyota, the feeling when you get in the car, and you KNOW it's gonna start.
have not looked closely in to the starter, but is it possible to get a starter from a nissan, toyota, mazda etc (heard that japanese cars got the best starters) or should i just make it easy for myself and get it from a 300 ?
and; just got a hold of some cheap speakers to replace the original in front. would the fit in the original covers ? they are 5,25" (13cm)
thanks
bodejodel
Post
by bodejodel » 10 Aug 2005 09:01 am
They could fit in the footwell but they will not fit in the door, those are 4".
Jeroen
Kakemnstr
Post
by Kakemnstr » 15 Aug 2005 12:06 pm
need 12V when egnition is on, for automatic driving-lights, where to get it from? any tips? cheers
Post
by redline » 15 Aug 2005 12:10 pm
any accessory that is only working with the ignition on would do i.e.heater blower,indicators wipers , rear fog ,etc
Kakemnstr
Post
by Kakemnstr » 15 Aug 2005 01:10 pm
of course, but the lights draws a lot of current, and you have kind of yelled at me for putting in bigger fuses..
had it on the same fuse at the dashboard-lights for a while now, but got a lot of trouble with the fuse.. and dont want my car to burn down
Post
by redline » 15 Aug 2005 01:27 pm
you can use one of those wires as the live feed to the relay then the heavier wire from the relay to the lights ,that way no damage will be done
Kakemnstr
Post
by Kakemnstr » 15 Aug 2005 02:26 pm
will do! thanks
